I've been shopping around for my first build for a couple weeks now and the biggest problem I'm having is almost every power supply I look at (on PC Picker, PC Case Gear or the manufacture's website) has no listed continues power spec. Only the beQuiet PSUs listed on PCCG have them so far.
 Every tech help site and channel I've looked at so far, including Linus and Jay's2Cents says that is a PSU doesn't have a listed cont. power, don't touch it.
 Is it really as rare as it seems, or am I just looking in the wrong places for those specs?
https://linustechtips.com/topic/788095-power-supply-continues-power-spec-missing/
PCpartpicker doesn't have it listed you have to look at the specs sheet. most have it
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
Continuous* and anything by EVGA or Corsair or any reputable brand with an 80+ certification will be good but I'm sure somewhere it is listed on the specs list. You could contact customer support if you have any questions about a product.
NO
EVGA 80+ White unites are tier 6
Corsair VS is very bad
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
No good PSU should have a "Continuous Wattage" and a "Max wattage".
The BeQuiet Pure Power 10 is a good budget unit:
https://www.pccasegear.com/products/38616/https://www.pccasegear.com/products/38617
Same with the XFX TS
https://www.pccasegear.com/products/33118/
All but the most budget/value power supplies from reputable brands will be able to output the maximum power advertised on their label continuously.
For some series, they only guarantee those numbers as long as the ambient temperature is below some threshold that's lower than the usual/expected 50c.
The most often "we cut corners/we overrate this psu" temperature is 40c but I've seen as low as 30c.
If you see less than 50c ambient, derate the psu by about 10-15%, and for less than 40c, derate by about 25% of maximum advertised on label... meaning don't buy such a psu if you're going to constantly go over that wattage for long periods of time
1 minute ago, That_PC_Kid said:
Corsair isn't bad and maybe I should've said 80+ Bronze and higher. 80+ White isn't good.
Like it says at the end:
- Never Trust A Brand
- Always Review The Model
Laptop:
Of course review the model! I never said don't. I just said anything from a reputable company is good and for the most part they are. You always need to read everything before you buy so you know exactly what you are getting.
Not anything.
Just link to the PSU tier list, and tell people to get tier 3 or higher. easy as that.
Laptop:
