I recently upgraded to a Gigabyte Windforce OC GTX 1060 6GB (not the G1) and im noticing an almost rattling noise when the fans hit 73%. I noticed this the first time i started a benchmark and the fans spun up, and I used afterburner to increase the fans slowly to find exactly where it starts, at 73%. My case is well cable managed and im not entirely in the mood to try to RMA, so any suggestions on what it could be?
AMD R5 1600 @ 3.6 GHz // 2x8GB Corsair LPX 3200MHz // Gigabyte Windforce OC 1060 6GB @ 2100MHz // Corsair RMx 650 // Crucial 275GB + Seagate 2TB 7200RPM // NZXT S340 Elite
https://linustechtips.com/topic/787728-gtx-1060-fan-noise/
if nothing is interfering with the fans themselves, then you need to RMA the card. it's slightly broken now, but in the future it will get much more broken.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
https://linustechtips.com/topic/787728-gtx-1060-fan-noise/#findComment-9924813
