36 minutes ago, EcDarkSky said:
Yes i just need to cool down heatpipes
I don't think anyone here knows.
Just... glue them or something? Thermal adhesive?
I have no clue.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/787717-cooling-heatpipes/#findComment-9924796
If you're trying to make your own cooler you can just copy current designs, 6 heat pipes needs 12 holes to come out through, so say 20 copper/alu plates need 12 holes drilled, 6 either side.
You'd need to have the pipes lined to the first plate to mark the holes, then use that as a template to drill the other plates. To space them evenly you could use washers. Use the same material as the plates for the washers.
The problem would be setting the height of the lowest plate as you don't want it sitting at the bottom of the pipes. Possibly a small bend in the pipes would stop it from sinking all the way down. Think of a right angle bend immediately followed by another going straight back up. This is starting to sound like a certain ghetto cooling video that didn't really work...
https://linustechtips.com/topic/787717-cooling-heatpipes/#findComment-9927629
On 06/02/2017 at 8:47 AM, EcDarkSky said:
Hi guys
How can I put fins on heatpipes because i need to cool them down and I have no client on how to do this.
Thanks for your help
Yes you can, but getting a proper thermal contact is a bit tricky. Loot at my build log for ideas (the silent cube).
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
https://linustechtips.com/topic/787717-cooling-heatpipes/#findComment-9931330
