So I've been told to change the cpu cooler that I have chosen for my new pc build, and  some people are telling me to get Air cooling cpu coolers, but i personal don't like them, they look too big and bulky and are going to way to heavy, from what i see, and you never know if a case can fit it, but in my opinion i don't like the look of them, and alot of people have told me not to buy the nzxt kraken, I chose that one because I like the pump cover, it looks cool and stylish, I also have found out by contacting nzxt that if i need a AM4 mount , that if i send the the receipt of purchase, and my info they will send me the mount for free, now lastly, i have been told by many people on here that corsair is the better choice, because its good and its cheap, now i have had a friend irl tell me, don't by anything from them because they are cheap, and not good quality, now i don't quite believe that, but am not sure what cpu cooler i should buy so I would just like alittle bit more help from the forms to help me choose, here is the pc part picker link if anybody needs to know any other info
https://pcpartpicker.com/list/HGPfgL
Also please stop recommending different hhd's am happy with WD and don't want to choose something else, you know it to me is kind of suspicious when 1 tb from a good or fairly good company can cost you about 50 dollars, and than another company can give you 3TB for only 40 dollars, to me thats just nope i don't trust it something is wrong with it
just like you all have your own personal choice, so do i, thank you
https://linustechtips.com/topic/787211-cpu-cooler-am-picky/
It's fine it's your build o with want you want no one can change except you
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/787211-cpu-cooler-am-picky/#findComment-9918521
What res are you playing at
I would get the Kraken X52 (I got it to, you'll really like it)
Quote
"(1) High Frame Rates (2) Ultra Graphics Settings (3) Cheap>>>>Choose only two" Chevaishr
https://myanimelist.net/profile/AnalCavity
PCPartPicker URL
https://pcpartpicker.com/b/bsJ8TW
https://linustechtips.com/topic/787211-cpu-cooler-am-picky/#findComment-9918523
Corsair ones are good, NZXT ones are good. They are the ones everyone uses and I don't see many rant threads going on about how terrible they are.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/787211-cpu-cooler-am-picky/#findComment-9918524
I WILL RECOMMEND ANOTHER HDD!
Seriously, black series is overpriced and Seagate is fine.
Plus you shouldn't look at parts as "how cheap they are"
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($215.98 @ PCM)
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  ($104.98 @ NCIX US)
Motherboard: ASRock - Fatal1ty X370 Gaming K4 ATX AM4 Motherboard  ($138.99 @ SuperBiiz)
Memory: G.Skill - Trident Z 16GB (2 x 8GB) DDR4-3200 Memory  ($134.88 @ OutletPC)
Storage: Samsung - 960 EVO 250GB M.2-2280 Solid State Drive  ($127.99 @ Amazon)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($65.89 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 8GB G1 Gaming Video Card  ($498.68 @ Amazon)
Case: Cooler Master - MasterCase 5 ATX Mid Tower Case  ($94.99 @ B&H)
Power Supply: EVGA - SuperNOVA G3 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.99 @ SuperBiiz)
Optical Drive: Asus - DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($18.69 @ OutletPC)
UPS: CyberPower - CP1500AVRLCD UPS  ($129.95 @ Amazon)
Total: $1611.01
Generated by PCPartPicker 2017-05-31 19:08 EDT-0400
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/787211-cpu-cooler-am-picky/#findComment-9918526
I've ran a Corsair H100i for the past 4 years mounted to my 4670k. It runs cool and quiet with it, and with the fans at 'quiet mode' it runs at max 65c with a 30c ambient.
Both Corsair and NZXT's watercoolers are based on designs from Asetek that they have licenced - it doesnt matter in terms of performance.
idk
https://linustechtips.com/topic/787211-cpu-cooler-am-picky/#findComment-9918527
Corsair is a good brand.  Any tower style cooler will fit your case. Id recommend getting the Kraken x52. Id change your hard drive. Blacks only difference is additional warranty I think two years. Wd blue or seagate have 2tb variants for significantly less and just as reliable. Id step down the 1600x to the non x cause there is no difference
https://linustechtips.com/topic/787211-cpu-cooler-am-picky/#findComment-9918533
Heatsinks aren't any heavier than AIO's. Weight in and of itself shouldn't be an issue unless you have a problem with the system being too heavy.
Aesthetics are subjective and you might as well go with whatever looks good to you if you're choosing a cooler pure based on aesthetics.
If not, tell us what you're looking for in a cooler.
https://linustechtips.com/topic/787211-cpu-cooler-am-picky/#findComment-9918725
