Not even going to ask about those wires..
Anyway does your motherboard have a little clip holding the GPU in next to the PCI lane? you need to release that first, and then just lightly pull it out.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
There should be some screws holding it in, if there are not or you have already removed them ,then there should be a clip on the motherboard, if there isn't, then pull it straight out, with a tiny bit if force it should come right out, if it doesn't use a bit more force, if it doesn't then, then something is holding it in that you have missed. :)
Case:NZXT H440   CPU:3570k @ 4.4ghz   Cooler:Prolimatech Megahalems w/ ap121 p/p  GPU:Gigabyte Windforce GTX 770  RAM:Crucial Ballistix Tactical Tracer 16gb 1600mhz  Mobo:Sabertooth Z77     PSU:Cooler Master Silent Pro M 700w   Wheel: Logitech G27 + joystick as handbrake Asus DGX 5.1        Mouse: Corsair M65     Keyboard: CM Storm Trigger Cherry MX black  Headphones: ATH-M50s    Phone: Nexus 5 32GB  Earphones: Sennheiser CX 400ii    SSD: 120gb 840 evo  HDD: WD Enterprise 2TB    AMP&DAC: Schiit Stack.
Pressed the PCIe switch (It'll be at the end of the PCIe lane, it should unlock and let the GPU pop out()
CPU: Intel Core i7-4790k @ 4.7 1.3v  with a Corsair H80 w/Dual SP120s - Motherboard: MSI Z97 gaming 5 - RAM: 4x4 G.Skill Ripjaws X @ 1600 - GPU: Dual PowerColour R9 290- SSD: Samsung NVME SM951 256GB-- PSU: Corsair RM 1000  - Case: NZXT H440 Black/red - Keyboard: Coolermaster CM storm Quickfire TK, Cherry MX blues - Mouse: Logitech G502 - Heaphones: Beyerdynamic DT 770 - Monitors: 3x VE248H Eyefinity 1080P -  Phone: iPhone 6S Plus               Please post your specifications in your post, signature or even better, system page on your profile!
Unscrew, remove clip, remove wires, remove GPU. If all else fails, use hammer.
Desktop: Intel Core i7-5820K, Corsair H115i, Asus X99-Deluxe/USB 3.1, G.Skill Ripjaws4 32GB 2800MHz CL16, Zotac RTX 3070, Samsung 950 Pro 512GB in Angelbird Wings PX1, Samsung 850 EVO 1TB, 5*Seagate 12TB, Cooler Master V1200, Phanteks Enthoo Luxe, Windows 10 Pro. Phillips 328P6VUBREB, Corsair Vengeance K95 RGB Cherry MX Brown, Logitech G502 X Plus, Sennheiser HD700.
AYANEO 2S: AMD 7800U, 32GB 7500MHz, 2TB WD SN850X. Windows 11.
Wow dude hehe that looks... a bit strange hehe.
All mainboards should have a lock for the PCIe. You should check this first.
I would cut the cable wraps to loose these cables a bit that you can work a little bit easier in that small case.
GreetZ Naj
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
i actually figured out how to get it out. there was a screw in the back cap, but the wiring is so bad because i bought this preset i didnt build it myself. I cant get it out cause of the wiring, im gonna have to cut one of the zipties and better organize it.
