GET RID OF THAT PSU!
DO IT!
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/786807-ryzen-build/#findComment-9913895
Just now, Richard N. said:
lol whats wrong with it? any suggestions?
The CXM450 $26, and a lot better and probably wont kill someone like yours.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/786807-ryzen-build/#findComment-9913902
1 minute ago, Richard N. said:
whats wrong with the PSU i picked? Im going to use the one you suggested but im curious.
Bad voltage regulation, cheap caps, low end features, etc
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/786807-ryzen-build/#findComment-9913921
It isn't anywhere close to that price. The EVGA PSU isn't going to kill someone anytime soon. Yes, it's sh*t, but it won't blow up unless you push it hard.
Generally, I'd recommend a Seasonic S12-II 520W. It's a solid PSU and it's fairly cheap for what it is, but the CXM PSU is fine.
Remember: Seasonic = SAFEsonic.
Also the build's fine.
https://linustechtips.com/topic/786807-ryzen-build/#findComment-9916156
It is. Check PCPartPicker again
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/786807-ryzen-build/#findComment-9916168
