Yes, an SSD generally makes computers boot way faster. If the PC is healthy and it's not a software or hardware problem, then you should see a massive performance boost for most loading/boot times. How long is it taking to boot now?
EDIT: And (at least in the US) you can get a 120GB Kingston HyperX SSD for $56 on Amazon. Mine took ages to ship, but it's here finally, and I'll be fresh installing Windows on it ASAP.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/786708-small-upgrade/#findComment-9912700
I agree with the above answers. As long as it is not a hardware or software issue, upgrading to a decent SSD, such as a Samsung 850 Evo, will make your kids computer MUCH faster.  I had a 2TB 7200 RPM HDD until about a year ago. When I upgraded to my 850 Evo, my boot times went from ~1 minute to 10-15 seconds.
https://linustechtips.com/topic/786708-small-upgrade/#findComment-9912718
just get a 120gb... life with a 60GB SSD is hell on earth unless you spend half your time cleaning shit off of it... i had one for 2-3 years and it was the worst thing ever, 120GB i can live with, i even have a 120GB SSD as my only drive in my school lapotp.
Builds:
https://linustechtips.com/topic/786708-small-upgrade/#findComment-9912746
Don't forget, since the OS will be on the SSD while the rest of your applications and games are on the HHD, that only the boot time will improve.  Since the rest of your software will be loading from the secondary drive (the HHD), then the time it takes for that software to load will not typically improve.
If you have to save for a while, like I did along with a lot of others, when possible get a Samsung Evo Pro 512 or something equivalent, then you can install your games as well as the OS onto the SSD.  That way everything will greatly improve.
Doing it this way greatly improved my overall loading times for everything, just not the OS.
Good Luck.
https://linustechtips.com/topic/786708-small-upgrade/#findComment-9912785
