This is my current plan for a mini ITX build. Any better components I should replace? This is at the very top of my budget, The usb C on the motherboard is something I would like to keep. Cheers
CPU: Intel - Core i7-7700 3.6GHz Quad-Core Processor  (£257.94 @ Aria PC)
CPU Cooler: Corsair - H45 Liquid CPU Cooler  (£40.00)
Motherboard: Gigabyte - GA-B250N-Phoenix WIFI Mini ITX LGA1151 Motherboard  (£103.71 @ CCL Computers)
Memory: Corsair - Vengeance LPX 8GB (1 x 8GB) DDR4-2666 Memory  (£57.60 @ Aria PC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£41.88 @ Aria PC)
Video Card: MSI - GeForce GTX 1060 6GB 6GB ARMOR OCV1 Video Card  (£229.84 @ More Computers)
Case: Cooler Master - MasterBox Lite 3 (Windowless) MicroATX Mini Tower Case  (£34.99 @ Novatech)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£48.36 @ Ebuyer)
Total: £815.32
https://linustechtips.com/topic/786158-mini-itx-build/
What is your budget? You could get a new case and an SSD?
https://linustechtips.com/topic/786158-mini-itx-build/#findComment-9906026
Total: £815.32
Change the case, AIO not necessary (depends on the case you want to use)
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/786158-mini-itx-build/#findComment-9908454
