Question for EU fellas
You can say a friend gave you the parts as gifts when you visited him so there's no invoice or anything and they're old parts therefore not worth much. As long as they're not in shiny new boxes you should be fine.
A trick some people use is to take the motherboard box and flip it around so that the box is all white/gray on the outside and looks like a generic packaging box. The boxes are generally made from corrugated cardboard that is bent in some places to take the shape of the box, so you can just get the cardboard to its original flat shape and re-bend it the other way.
Or just take the components out of their boxes along with the invoices and warranty pages, mail the packaging and invoices and documentation to you (as a package or something) and then put the parts in some plain bags in a box in your trunk or back seat to make them look as used parts.
