Finally took the plunge and put together my first custom loop! Here's the only picture I have so far, all EK parts except the coolant and the fitting couplers that convert from hard tubing to soft in the back of the case for the radiator(s). Gpu loop will be next! Coolant is mayhem pastel white, and lighting is corsairs lighting node pro
https://linustechtips.com/topic/782937-first-custom-water-loop/
14 minutes ago, spadz93 said:
Thermaltake Tower 900
Love the work you done there. Great job. :)
[CPU] i5-4690K @ 4.5GHz with NZXT Kraken X61 [MOBO] Asus Z97-AR [Memory] HyperX Fury 32GB DDR3-1600 [Storage] Samsung 840 EVO 500GB & WD 1TB Black & Hitachi 1TB [GPU] Gigabyte GTX 1080 8GB Xtreme Gaming [Case] Corsair Air 540 [PSU] Cooler Master V1000 [Case Fan] Corsair SP140 LED Fan x 3 & SP120 LED Fan x 3 [Display] Main: Philips 31.5" FULL HD IPS | Side: Philips 28" 4K UHD [Keyboard] Razer Blackwidow Ultimate Stealth Edition [Mouse] Razer Ouroboros [Mouse Pad] Razer Firefly [Sound] BOSE Companion 5 Multimedia Speaker System
https://linustechtips.com/topic/782937-first-custom-water-loop/#findComment-9869363
52 minutes ago, Stevoisboss said:
Never heard of it before but I really like it. Pretty unique.
Thank you both!! The case is pretty unheard of since it's usually not a mainstream case (or so I would imagine). I say this because the thing is actually huge, quite literally coming in at the size of a small mini fridge
https://linustechtips.com/topic/782937-first-custom-water-loop/#findComment-9869494
Haha I saw this case in Black at my local Fry's Electronics. I must say it is my favorite Thermaltake case thus far. It is a really unique case. However don't try and build an air-cooled system in it (even an AIO won't provide cooling to their full potential), as it was designed for watercooling first.
Good job though ^_^ I also did my first custom loop on my brother's system, and it is beautiful.
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
https://linustechtips.com/topic/782937-first-custom-water-loop/#findComment-9869535
Yeah, I definitely hear you, I had a corsair h100i v2 from my previous build (nzxt  h440 based) and I could't even mount the radiator anywhere. The only AIO that would work is a 120/140mm one on the top exhaust fan lol, had to run the stock intel cooler for a few weeks while I waited for the rest of my loop parts to come in
https://linustechtips.com/topic/782937-first-custom-water-loop/#findComment-9869543
Just now, spadz93 said:
Yeah, I definitely hear you, I had a corsair h100i v2 from my previous build (nzxt  h440 based) and I could't even mount it the radiator anywhere. The only AIO that would work is a 120/140mm one on the top exhaust fan lol, had to run the stock intel cooler for a few weeks while I waited for the rest of my loop parts to come in
Thermaltake showed a bracket in their pictures for their Tower 900 holding their Water 3.0 Ultimate RGB :/.
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
https://linustechtips.com/topic/782937-first-custom-water-loop/#findComment-9869550
This i am curious about, I'll have to dig it up. I guess if the hoses are long enough it's possible to reach around to the back?
https://linustechtips.com/topic/782937-first-custom-water-loop/#findComment-9869560
http://www.thermaltake.com/Chassis/Super_Tower_/The_Tower/C_00002974/The_Tower_900/design.htm
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
https://linustechtips.com/topic/782937-first-custom-water-loop/#findComment-9869575
So, if i'm reading this right, the rad would literally just sit on top of the HDD cage? Lol
pretty much.
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
https://linustechtips.com/topic/782937-first-custom-water-loop/#findComment-9869614
1 minute ago, JurunceNK said:
pretty much.
I feel like that would be so ineffective, it would either be pulling heat down (against laws of physics) or it would be pushing heat up onto the motherboard... Oh well, i'm custom loop lol
https://linustechtips.com/topic/782937-first-custom-water-loop/#findComment-9869618
