Best Air Cooler for AM4
Solved by porina,
6 minutes ago, GanstaKingofSA said:Case is a GUNGNIR X
The case apparently supports up to 180mm height on CPU cooler which should be enough for most thing. The Noctua U14S is nominally 165mm so is fine if you choose to go that route, or others in its size class.
Featured Topics
alexfic ·
Posted in New Builds and Planning3 -
1
BryanOttawaDetroit ·
Posted in General Discussion1 -
2
2
GoStormPlays ·
Posted in WHALE LAN1 -
GoStormPlays ·
Posted in General Discussion6 -
9
jordan_wills ·
Posted in New Builds and Planning2 -
5
