  • liquid metal TIMs used between the IHS and the cooler are a waste of time and money
  • liquid metal TIMs should be primarily used between the CPU bare die and the IHS
  • liquid metal TIMs should not be used with Aluminium heatsinks
  • liquid metal TIMs can be used with Copper heatsinks for couple of months - they do amalgamate eventually pitting the surface of the Copper heatsink
  • liquid metal TIMs do not amalgamate with Nickel plated heatsinks
what you should take away from all of this: liquid metal TIMs are not for the average joe, they are used primarily by people who do LN2 cooling and for people who seek maximum performance for limited periods of time (extreme overclocking/benchmarking)
Alright thankyou. So you think I shouldn't use this to lower my temps as apposed to the thermal paste on the x62 which doesn't seem great.
i7 7700k OC 5.1ghz
1080ti EVGA FTW3
960 Samsung Pro 512gb
32gb Vengeance LPX 3200mhz
z270 Extreme 4 mobo
x62 AIO.
I doubt you have a TIM problem
you haven't said what CPU are you using and what temps are you getting and if you OC it
Primarily used for people delidding, not LN2 guys. I think there's a risk with dies cracking when the temp gets way too cold for liquid metal "pastes".
In fact he is Giving you info that say you will damage your x62 block as the TIM you've chosen  reacts to copper.
i7 7700k 48 idle 90 load no OC yet..
i7 7700k OC 5.1ghz
1080ti EVGA FTW3
z270 Extreme 4 mobo
x62 AIO.
Kabys are known to have problems with the TIM (it's less of a TIM problem and a distance between the die and IHS problem) in between the CPU die and the IHS - most people delid these CPUs are replace the TIM
https://www.hardocp.com/article/2017/01/19/intel_kaby_lake_i77700k_cpu_delid_relid_results
Thanks. So you would advise under no circumstances do not use the liquid pro on my cpu with the x62?
i7 7700k OC 5.1ghz
1080ti EVGA FTW3
z270 Extreme 4 mobo
x62 AIO.
15 minutes ago, zMeul said:
don't use it if you do not plan to change it frequently
the are good TIMs out there that are not liquid metal
Let me rephrase. Can this be used with the kraken x62, someone mentioned copper being an issue. Thanks
i7 7700k OC 5.1ghz
1080ti EVGA FTW3
z270 Extreme 4 mobo
x62 AIO.
It'll diffuse into the copper and make it ugly.
You really shouldn't bother with liquid metals unless you're putting it on the die directly.  It's a lot more chance of error in application and there's no temperature gains to be had from it.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
3 hours ago, zMeul said:
can you use it? sure - but not for long because it will pit the Cu surface after couple of months
What paste would you recommend? I've got it on now but I'll probably take it off, I applied it all evenly and it was a pain in the ass to spread on. Temp is reading 24 on idle now so not too sure what happened earlier
i7 7700k OC 5.1ghz
1080ti EVGA FTW3
z270 Extreme 4 mobo
x62 AIO.
you might've not installed the plate properly
what paste? dunno, there are quite a lot of reviews out there
Arctic Silver 5 ?! for example
ps: getting that liquid metal off will be a bitch
