Hey guys i have recently bought a new pc and i was wondering if you could help me find the best setup for my case airflow
I have in my possession :
H100i V2 (Two of the following 120mm fans would have to go on top of its radiator)
4x 120mm Magnetic Levitation Fans By Corsair
2x 140mm Magnetic Levitation Fans By Corsair
2x 120mm SP Series Fans By Corsair
The 400C Case has the ability to have :
FRONT : Up to 3x 120mm fans or 2x 140mm fans
TOP : Up to 2x 140mm fans or 2x 120mm fans
BACK : Up to 1x 120mm fan
My Radiator can either be at the top or at the front of the case.
Could use some help from you guys to decide which path of airflow would suit the best.
Right now i have the radiator in the Front set as intake , 2x 140mm fans on the top set as intake  and one 120mm exhaust fan at the back.
I would like to hear your guys's thoughts about whether my current settings make the airflow in my case bad or not and whether i should switch it out and if so then to what?
Thank you all in advance for trying to help!
https://linustechtips.com/topic/781170-best-setting-for-400c/
