im just about to clone my old HDD to new SSD im using macrium . my problem is my HDD is partitioned . C and D . the C drive is only for OS and couple of programs and the D is my apps and games etc . how to do this ? copy the 2 partitions C and D ? or just an C ?
i just want an OS to put in my SSD nothing else . so just copy the C right ?
https://linustechtips.com/topic/778508-cloning-help/
I would highly recommend you do a fresh install instead of cloning as cloning can cause both performance and stability issues.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/778508-cloning-help/#findComment-9818545
Just now, BudgetBoy said:
naaaaa dont want to .
An extra ten minutes of work is worth not risking performance and stability issues.
PSU Tier List | CoC
https://linustechtips.com/topic/778508-cloning-help/#findComment-9818553
This is the best advice you will ever get, and if you running 1 hdd don't really bother to partition it, just install your games into a games folder and that is that. you don't get any benefits of splitting them.
@djdwosk97 meh.. we tried :)
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
https://linustechtips.com/topic/778508-cloning-help/#findComment-9818557
You select the entire disk and then remove the D: partition.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/778508-cloning-help/#findComment-9818558
But what if he wants the D ? :P:P:P Sorry I couldn't help myself
Redstone:
Obsidian:
https://linustechtips.com/topic/778508-cloning-help/#findComment-9818561
We all want the D:, but that doesn't mean we should have two of them.
Ditto.
https://linustechtips.com/topic/778508-cloning-help/#findComment-9818563
naaa i just want the C drive . maybe its worth a try
You need the other parts as they may contain the backups for your system.
https://linustechtips.com/topic/778508-cloning-help/#findComment-9818572
57 minutes ago, SCGazelle said:
also make sure you delete the c partition on the hdd and increase the d partition to fill up the entire drive.
sorry guys its working :D now im using my sdd :D im starting to format my old C partition
https://linustechtips.com/topic/778508-cloning-help/#findComment-9818723
Use diskpart to delete the partitions you don't need.
https://linustechtips.com/topic/778508-cloning-help/#findComment-9818739
