Hi there,
What case would you recommend for a top mounted Corsair H110i equipped with stock fans, and to still have room for the top 5.25 cage?
Bonus points: tempered glass baby!!
Thanks
TJ
Phanteks Enthoo Pro M Temperd and Enthoo Luxe Tempered
CPU: i7 3770K | MB: EVGA Z77 FTW | RAM: HyperX Savage 2400Mhz 16GB | GPU: R9 280X Toxic | Cooler: Scythe Fuma | PSU: CoolerMaster B600
SSD: Crucial MX300 525GB | HDD: Seagate Barracuda 7200.12 500GB - Toshiba DT01ACA300 3TB
https://linustechtips.com/topic/777943-case-recommendation/#findComment-9811774
I can tell you for sure that the rad barely fits on top of Phanteks Enthoo Pro M and there's no room for any 5.25" device, except a fan controller. I should have told in the beginning that Enthoo Pro M is already tested, so i have that as a reference case. Enthoo Luxe... not a bad choice, i'll take a look into that. Thanks.
https://linustechtips.com/topic/777943-case-recommendation/#findComment-9811991
Dark base 900 (HardwareCanucks PC Case of they Year 2016)
Cooler Master Master Case Maker 5t (Not 100% sure about this one, I cant find photos of a top RAD with the 5.25" still installed)
Thermaltake Supressor F31 I have found pictures of this one with a 240mm RAD with the 5.25 still installed!
https://linustechtips.com/topic/777943-case-recommendation/#findComment-9815600
