Hello,
So recently I got my hands on brand new Ryzen 5 1600, I OCed it on stock cooler to 3.8 with 1.375 voltage ( I tried rise it to 3.85 but it was unstable and I dotn want to rise voltage on stock cooler and 24/7 usage)
So question si next:
In Ryzen Maste utility temperature stuck at 79-80 (79 msot of the time) buti n aida64 stress test it shows like 64??
So what should I believe? I heard that X versions got that -20 degree thing but is it goes the same with my 1600? and its morethan 20.
https://linustechtips.com/topic/777808-ryzen-5-1600-temperature-question/
In Ryzen Mast we trust
Some programs haven't been updated for ryzen yet so you may get inaccurate temperature reports.
Anything from AMD you should trust.
hello!
is it me you're looking for?
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
Cooler: Dark Rock Pro 3
RAM: 32GB DDR4
GPU: GTX 1080
Storage: 1TB 850 Evo, 1TB HDD, bunch of external hard drives
PSU: EVGA G2 750w
Peripherals: Logitech G502, Ducky One 711
Audio: Xonar U7, O2 amplifier (RIP), HD6XX
Monitors: 4k 24" Dell monitor, 1080p 24" Asus monitor
Laptop:
-Overkill Dell XPS
Fully maxed out early 2017 Dell XPS 15, GTX 1050 4GB, 7700HQ, 1TB nvme SSD, 32GB RAM, 4k display. 97Whr battery :x
Dell was having a $600 off sale for the fully specced out model, so I decided to get it :P
-Crapbook
Fully specced out early 2013 Macbook "pro" with gt 650m and constant 105c temperature on the CPU (GPU is 80-90C) when doing anything intensive...
A 2013 laptop with a regular sized battery still has better battery life than a 2017 laptop with a massive battery! I think this is a testament to apple's ability at making laptops, or maybe how little CPU technology has improved even 4+ years later (at least, until the recent introduction of 15W 4 core CPUs). Anyway, I'm never going to get a 35W CPU laptop again unless battery technology becomes ~5x better than as it is in 2018.
Apple knows how to make proper consumer-grade laptops (they don't know how to make pro laptops though). I guess this mostly software power efficiency related, but getting a mac makes perfect sense if you want a portable/powerful laptop that can do anything you want it to with great battery life.
Aida is showing wrong temps right now.
Temps from Ryzen master are the correct ones.
79°C max temp during aida64 CPU + FPU + cache isn't that bad. In normal workload you probbably won't go beyond 70°C.
And you can always buy aftermarket cooler, to lower your temps a bit.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
