Okay, so I'm trying to choose a new case for when I upgrade my pc. I'm probably gonna get an ATX motherboard but if the cases are massively I'll consider an mATX cause no SLI.
Only real requirements are that its black or has doors over the 5.25" drive bays, has 3x 120mm fan slots and has a flat top cause I keep my PS4 on top. No window required cause it sits under my desk. Some cable management would be an added bonus.
No real requirement of brand just the usual rule of something reputable.
Thanks
|| CPU: AMD Ryzen 5 1600 (@3.9GHz) || Motherboard: ASUS Prime B350 Plus || Cooler: Arctic Freezer 33 eSports Edition || GPU: EVGA GTX 1070 SC || Memory: 16GB G.Skill Trident Z RGB C16 (@2933MHz) || SSD: SanDisk 128GB || HDD: WD Blue 2TB, Toshiba 2TB, Transcend 1TB || PSU: Corsair RM550x || Case: Fractal Design Focus G || Monitor: 2x AOC 23” I2369VM IPS Full HD, Samsung 32" LED TV Monitor || Mouse: Logitech G703 Wireless || Keyboard: Cooler Master MK750 RGB (Cherry MX Brown) || Speakers: Dell Stereo Speakers || Headphones: Sennheiser HD 4.40 BT / Samsung Galaxy Buds ||
https://linustechtips.com/topic/777745-case-help/
On 2017-5-10 at 8:58 AM, Abaris said:
Corsair Carbide 330R
It is black. Flat top. 3x120mm fan slots. And a front cover.
http://www.corsair.com/en-eu/carbide-series-330r-quiet-mid-tower-case
Is it really worth that much? It's like £90
https://linustechtips.com/topic/777745-case-help/#findComment-9815413
Fractal Define R5 (since you require 5.25" bays) It will also be super quiet because of the sound dampening foam. Fractal Design makes some of the best cases on the market, period. (That Corsair 330R is pretty good too)
https://linustechtips.com/topic/777745-case-help/#findComment-9815474
