Ok so I had an idea of what I wanted but some wise men on the forums pointed me in a better direction. Here's what I'm looking at.
My max budget is 500$.
I need to order tomorrow or the day after.
https://pcpartpicker.com/list/6J2BHN
  • I Live in the US.
  • I am building for using cad software and occasionally playing games like arma and bf4.
  • I am planning on upgrading cpu and gpu.
  • I want to tinker with overclocking the gpu.
  • I already have peripherals.
  • I will be using Windows 10.
Thanks
https://linustechtips.com/topic/776877-updated-first-pc-build-please-nitpick/
Pentium will not keep up
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
Alright, let's nitpick:
A G4560 is going to have a really hard time keeping up with what you're asking. My real recommendation is to go out and find yourself an H81 motherboard, 16GB of DDR3 RAM and a Xeon E3-1231V3 instead. It'll be pricier...maybe buy the RAM in stages? It'll be worth every penny, though. The 1231V3 is an i7-4770 without the integrated graphics, and if you've got a GPU in the budget anyway, who cares?
Kingston SSDs are godawful. The one that came built into my Acer 2-in-1 barely outpaces a 7200RPM hard drive on startup after about 1.5 years of light, occasional use (I really should sell that laptop, tbqh).
The GTX 1050 Ti is a pretty poor choice with the RX 470 and 570 out there. If you have power draw or size concerns, it's a solid bet, but a 470 will handily beat it in most games. Arma and BF4 need that horsepower.
The SPEC-01is a decent looking case, but you've got a Micro ATX motherboard. Nothing wrong with putting a mATX board in that case, but you can save a few bucks and get a system that will end up looking better by going to a mATX case.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
CPU: Intel - Core i5-7400 3.0GHz Quad-Core Processor  ($176.59 @ OutletPC)
Motherboard: ASRock - B250M-HDV Micro ATX LGA1151 Motherboard  ($62.99 @ SuperBiiz)
Memory: Patriot - 8GB (2 x 4GB) DDR4-2133 Memory  ($52.99 @ Amazon)
Storage: Kingston - SSDNow UV400 120GB 2.5" Solid State Drive  ($50.99 @ B&H)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.45 @ OutletPC)
Video Card: XFX - Radeon RX 470 4GB HS Triple X Video Card  ($164.99 @ Best Buy)
Case: Rosewill - SRM-01 MicroATX Mini Tower Case  ($19.99 @ Jet)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($29.99 @ Newegg)
Total: $605.98
Generated by PCPartPicker 2017-05-07 23:38 EDT-0400
