Posted May 8, 2017 I did some brief searching and some of Googling, but didn't find much. Feel free to link me to something relevant as I would love it. I have a bunch of spare parts from work that they were happy that I take from a failed datacenter project. I got a (proprietary mounting) dual CPU SuperMicro board with 256GB of DDR3 from a custom 1U chassis. I dropped some cash and put dual e5-2670s in it. I put Windows 10 in it and found that everything seemed to run perfectly stable, but the machine won't restart regularly. It has all the updates and newest drivers from SuperMicro. It just hangs on reboot.Shut down is fine though. I thought the board was faulty at first, but Linux doesn't seem to have this issue. I went though and turned off a few suggested objects like Fast Boot (I think that is what it was called in Windows). I moved onto another (SuperMicro) board that I was given that was more ATX(ish) and put it in a case with half the ram and one CPU. I found that it too has the issue! I am not immediately pressed to fix this, but I was thinking if I could resolve the reboot issue, I might build a custom case for the first board, or go buy another board. I have been looking at some Intel boards s2600 (I think was the model ), but the boards I like the most seem to be SuperMicro (PCIE 16 slots and massive amount of DIMMs). I am tempted to buy another board, but I feel dumb as I will probably have the same issue. Has anyone here heard of this issue? The current single CPU system looks like: CASE: BitFenix NEOS CPU: e5-2670 v1 w/ Hyper T4 (fits in case) RAM: 8x16GB GPU: GTX 970 SSD: Currently 2x850Pro 128 in Raid0 HDD: 3X3TB RAID 5 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 8, 2017 I don't think windows 10 home supports that much Ram.Correct me if i'm wrong though My life Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 8, 2017 2 minutes ago, Himommies said: I don't think windows 10 home supports that much Ram.Correct me if i'm wrong though ^ I'm pretty sure that max is 32GB, even pro max at 64 or 128GB. I would try window server. Magical Pineapples
