Hey guys,
So internet speeds of up to 1 gigabytes/second just rolled out in my area and I was wondering what would be the best Wifi solution to take advantage of these blisteringly fast speeds? I thought of building my own pfSense router and then using Ubiquiti access points, but I'm sure there are more solutions than that. It wouldn't be just over Ethernet. It would be 1 GBps Wifi and it would have to reach those speeds across a lot of devices. Any thoughts?
Thanks!
Ethan
Current System: CPU: Intel i7 4790K 4.6 GHz @ 1.28 volts | Motherboard: MSI Z97S SLI Krait Edition | RAM: Corsair Vengeance 16GB 1600 MHz + G.Skill Ripjaws 8GB 1866 MHz (Total RAM: 24GB) | Cooling: Corsair H100i | GPU: Zotac GTX 1070 AMP! | Storage: WD Black 1TB + Samsung 960 EVO 500GB + SanDisk 500GB SSD + WD Blue 4TB + Seagate 2TB External + Rosewill 3TB External | PSU: Corsair RM850x | Case: NZXT S340 Elite
Planned Upgrades: No idea
https://linustechtips.com/topic/776795-fastest-wifi-possible/
thats about the best you can do. If you want better than unfiy your spending a lot for cisco or broadcom(rukus) aps
Your not gonna get 1gig over wireles.
https://linustechtips.com/topic/776795-fastest-wifi-possible/#findComment-9797387
Just now, mok said:
1. buy a good wireless router
2. build your own router with pfsense + buy access points
Ok. What would be some access points that could keep up with the Wifi speed as well as the router? I want zero bottlenecks
https://linustechtips.com/topic/776795-fastest-wifi-possible/#findComment-9797389
2 minutes ago, Windspeed36 said:
Is there existing cabling throughout the building?
Are you able to provide a floorplan?
What's your budget?
Uh so it's my dad's coffee shop and I don't have floorplans. I'm not looking for 1 GBps Ethernet though. I want the fastest Wifi possible. Period.
https://linustechtips.com/topic/776795-fastest-wifi-possible/#findComment-9797399
You're almost NEVER going to get the rated throughput on wireless because of a myriad of different factors and the amount of time and money you usually need to spend to overcome these factors is greatly outweighed by the ability to run some wires.
Just a few things off the top of my head:
For equipment, ideally you'd want 802.11AC Wave 2 capable access points but 802.11AC Wave 1 should suffice. You have to take into account interference from wireless access points nearby, other wireless sources and interferers such as concrete or thick wooden walls. The number of devices and their capabilities will also greatly determine the speed. Most phones cannot get gigabit throughput even if connected to the fastest wifi.
You also need 1Gbps capable wiring to actually use those speeds, a mesh network will generally hamstring the speeds.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/776795-fastest-wifi-possible/#findComment-9797408
no way you have 1GBps internet.
you have 1Gbps internet
note the little B
it means that it's gigabit, not gigabyte, and is 8 times slower.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/776795-fastest-wifi-possible/#findComment-9797409
Laptop:
https://linustechtips.com/topic/776795-fastest-wifi-possible/#findComment-9797414
note the little B
No sir. It's 1 GBps
https://linustechtips.com/topic/776795-fastest-wifi-possible/#findComment-9797418
Just now, RadiatingLight said:
Would this be better than a DIY pfSense router? Like I said, I want the fastest out there
https://linustechtips.com/topic/776795-fastest-wifi-possible/#findComment-9797424
Just now, ethaDAboss11 said:
No sir. It's 1 GBps
Really!? Holy crap.
it really wouldn't matter that much though, because literally no devices can access that kind of bandwith, so your best bet is to have a router with multiple bands so 8 devices can all have 1Gbps
Laptop:
https://linustechtips.com/topic/776795-fastest-wifi-possible/#findComment-9797433
No sir. It's 1 GBps
Nobody offers 1 gigabyte per second. Its either 1 Gigabit, 2 Gigabit (comcast is testing this now) or 10 Gigabit.
1GigaByte is 8 Gigabit
Prior Build Log/PC:
https://linustechtips.com/topic/776795-fastest-wifi-possible/#findComment-9797435
Ahh thanks for clarifying. So I guess it would be 8 Gigabit. But I'm positive it's speeds of 1 gigabyte per second.
https://linustechtips.com/topic/776795-fastest-wifi-possible/#findComment-9797445
2 minutes ago, RadiatingLight said:
Really!? Holy crap.
Ok so then what equipment would I need to maximize Wifi speeds for devices such as phones, iPads/tablets, and laptops? Like I said, it's for my dad's coffee shop and he wanted me to do some research but I'm too lazy to do so and that's why I came on LTT forums lol
https://linustechtips.com/topic/776795-fastest-wifi-possible/#findComment-9797451
I almost garantee its 1 gigabit. Your gonna need some highend stuff to run 10gig which would be needed for a 8gig connection
https://linustechtips.com/topic/776795-fastest-wifi-possible/#findComment-9797455
If thats the case, then damn that bill has to be a heart attack every month. Comcast charges $199 a month plus $1000 installation for their 2 Gigabit service. I hate to see that internet bill.
https://linustechtips.com/topic/776795-fastest-wifi-possible/#findComment-9797456
No sir. It is most definitely 1 gigabyte per second
https://linustechtips.com/topic/776795-fastest-wifi-possible/#findComment-9797459
I very much doubt you've got 8Gbit connected to the premise. If you do, you'll be spending up big to route that correctly.
Were you looking to charge customers for WiFi use?
https://linustechtips.com/topic/776795-fastest-wifi-possible/#findComment-9797460
Budget?
Low- get a few of these https://www.amazon.com/Ubiquiti-Networks-802-11ac-Dual-Radio-UAP-AC-PRO-US/dp/B015PRO512
High- Get a few of these - https://www.amazon.com/Ruckus-Performance-R510-US00-Dual-Band-901-R510-US00/dp/B01LZZ7VWH/ref=sr_1_1?ie=UTF8&qid=1494194844&sr=8-1&keywords=ruckus+r510
Really high get a few of these --https://www.amazon.com/Ruckus-Wireless-ZoneFlex-R710-Dual-Band/dp/B012E4BWXI/ref=sr_1_2?s=electronics&ie=UTF8&qid=1494194881&sr=1-2&keywords=ruckus+r710
https://linustechtips.com/topic/776795-fastest-wifi-possible/#findComment-9797466
No actually it's $40/month for life. They're in direct competition with Comcast
https://linustechtips.com/topic/776795-fastest-wifi-possible/#findComment-9797467
No
https://linustechtips.com/topic/776795-fastest-wifi-possible/#findComment-9797470
