Watt requirements for overclocking
Solved by 79wjd,
2 minutes ago, L0gic said:A i5 uses less power, and the "how many watts do i need" post says that it needs 550W when overclocked, but an i7 which uses more power only needs 450W when overclocked? I dont get it.
He's being generous and taking into account lower quality units. You can overclock an i5/i7+GTX 960 on a good 300 watt psu, but then you have no headroom if you wanted to throw in something more power hungry.
