Excuse my absence of actual pictures for a minute here (my camera sensor is on its annual cleaning/maintenance). In the meantime, could I get opinions on these proposed loops:
Loop 1 (Res->pump->Rad 1->Rad 2->MoBo->CPU->GPU->Res): post-41243-0-17443300-1384792847_thumb.p
Loop 2 (Res->pump->Rad 1->Rad 2->CPU->GPU->Res): post-41243-0-57908200-1384792864_thumb.p
Loop 3 (Res->pump->CPU->MoBo->Rad 2->GPU->Rad 1->Res): post-41243-0-30956100-1384792871_thumb.p
Loop 4 (Res->pump->CPU->Rad 2->GPU->Rad 1->Res): post-41243-0-95461000-1384792875_thumb.p
The pump is behind rad 1.
Loops 1 and 3 are the major changes, loops 2 and 4 are just omissions of cooling the motherboard (undecided yet, will be getting the EK blocks for the M6F if I decide to do so). Now, loop 1 (and 2 accordingly) will be the cleanest runs but this will involve rad->rad and CPU->dual GPU. Also the CPU to GPU connection might be tight once my koolance QDCs get here (not a deal breaker of course, I got plenty of angle adapters). Loop 3/4 will not be easy to route but makes sense thermodynamically. Note that I can't turn around rad 2 because my 5 1/2" bays will be pretty much occupied. I also have both rads on intake if that changes anything.
Any thoughts will be appreciated.
https://linustechtips.com/topic/77611-thoughts-on-loop-order/
I would go with the second loop, much cleaner, no tight bends.
Its also straight forward, what I like :D
EDIT: Have just seen you want to cool you mobo, If you want your mobo in there, do #1 :D Else the #2
My Rig "Jenova" Ryzen 7 3900X with EK Supremacy Elite, RTX3090 with EK Fullcover Acetal + Nickel & EK Backplate, Corsair AX1200i (sleeved), ASUS X570-E, 4x 8gb Corsair Vengeance Pro RGB 3800MHz 16CL, 500gb Samsung 980 Pro, Raijintek Paean
https://linustechtips.com/topic/77611-thoughts-on-loop-order/#findComment-1065088
Does it matter if the "hot coolant" enters the pump? I imagine it would only be a few degree centigrades above the mean loop temperature but anyone know if this can influence the life of the pump?
Also, the GPU will be getting the "hot" out-take from the CPU block. I definitely would prefer Loop 1/2 for design but wanted to be sure it won't really bite my overclocking potential.
https://linustechtips.com/topic/77611-thoughts-on-loop-order/#findComment-1065116
The peak and the lowest temp in a coolant will be off by about 1-2 °C, you have to look at it as a whole :D
https://linustechtips.com/topic/77611-thoughts-on-loop-order/#findComment-1065158
Loop 1 (Res->pump->Rad 1->Rad 2->MoBo->CPU->GPU->Res): attachicon.gifLoop 1.png
Loop 2 (Res->pump->Rad 1->Rad 2->CPU->GPU->Res): attachicon.gifLoop 2.png
Loop 3 (Res->pump->CPU->MoBo->Rad 2->GPU->Rad 1->Res): attachicon.gifLoop 3.png
Loop 4 (Res->pump->CPU->Rad 2->GPU->Rad 1->Res): attachicon.gifLoop 4.png
What case is this?
https://linustechtips.com/topic/77611-thoughts-on-loop-order/#findComment-1065183
Corsair 900D, I have an XSPC AX480 on top and an Alphacool Monsta 480 on the bottom. The CPU is an i7-4770k with a Koolance 380I block. The reservoir is a 400mm FrozenQ Liquid Fusion V-series cylinder and the pump is a Swiftech MCP35x on its heatsink (behind the monsta rad in the bottom).
https://linustechtips.com/topic/77611-thoughts-on-loop-order/#findComment-1065207
Loop order makes no difference,choose the order with the least amount of tubing.
SR-2-2x X5650 Xeons-3x 670 FTW-1x 120Gb Force GT-1x 240Gb Force GT-1tb WD Green-12Gb Dom GT 1866-Platimax 1500w-2x HK3-2xD5-24v controller-3x RX 480's-3x NiBlk HK GPU blocks-Koolance tops-BP res-15x SP120's-Little Devil V8.
https://linustechtips.com/topic/77611-thoughts-on-loop-order/#findComment-1065238
Correct loop order, res/pump/whatever/res
Lian Li PC-V359WRX Micro-ATX Case | Intel 5960X Extreme 3.00GHz | ASRock Fatal1ty X99M KILLER | Crucial 32 GB 2666 DDR4 | Thermaltake NiC C5 | EVGA Supernova 1200W P2 | 2x 240GB OCZ Radeon R7 | 2x 256 GB Samsung 840 Series Pro | 2 X 120GB Samsung 840 EVO | 6x NF-F12’s | Place Holder GPU R9 290X |
Links Current 5960X Old FX9590
https://linustechtips.com/topic/77611-thoughts-on-loop-order/#findComment-1066044
  • 3 weeks later...
