Can i get a power supply just for case fans?
By
TheEndIsNear
in Cooling
in Cooling
Solved by Godlygamer23,
Power supplies will only draw what's required to give the required output. The power supply will have an efficiency rating at different load levels. The idea that the load on the power supply shouldn't be too low is usually due to the efficiency - if you get a 24-pin power connector adapter, you can short both power supplies to turn on at the same time.
Featured Topics
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
