Increasing the speed of a case fan?
Solved by AvocadosGuac,
Everything looks fine.
If the RPM is over what it says it could mean the sensor is reading incorrectly.
If you were 200-300 RMP over then i would be concerned cause that would be most likely a voltage problem.
IN ALL; You will be fine as-is.
Featured Topics
xJDL ·
Posted in Troubleshooting0 -
Marie Rose ·
Posted in Power Supplies8 -
7
3
6
13
10
Tamgam12 ·
Posted in New Builds and Planning6 -
remo233 ·
Posted in New Builds and Planning24 -
5
