Screen freezes with weird lines, system shuts down
rip
Specs (it's old and a prebuilt):  Pentium G640T, 2GBx1 RAM DDR3 @ 532Mhz, 500GB Seagate Barracuda HDD (ST500DM002-1BD142), Windows 7
Motherboard: https://support.hp.com/us-en/product/hp-pavilion-p2-1200-desktop-pc-series/5258516/model/5264148/document/c03333871
PSU: none, the power is supplied directly to the motherboard
So whenever the screen gives weird lines like this the PC freezes and then I either have to manually force shutdown (holding Power button) or it shuts off then turns on itself back
Then I get to a screen saying whether I want to boot into Safe mode, safe mode with networking... or start windows normally
Safe mode or normal mode will result sometime in another crash/restart.
Sometimes it happens and sometimes I will be able to use my computer for a long period of time
Event Viewer shows no errors however. The only errors are from my antivirus program which seems irrelevant
Quote
The BkavFwDrv service failed to start due to the following error:
The system cannot find the file specified.
Quote
The following boot-start or system-start driver(s) failed to load:
BkavChkUI
BkavCoreLib
BkavSD
SysLib
SysLib0
SysLib1
SysLib2
SysLib3
SysLib4
SysLib5
SysLib6
SysLib7
And this which is more irrelevant I guess
Quote
The Windows Update service hung on starting.
It could also thermal throttle? But it's not an error, it was under Information level
Quote
Processor 1 in group 0 exposes the following:
3 idle state(s)
9 performance state(s)
0 throttle state(s)
I would try straight forward solution first rather than saying I need new components/too old throw it away
Pics here in spoiler
rip
