Right, I need some info on this little guy. Summer is fast approaching, and since my room will happily climb towards the 31C mark, I need to know just how this little bugger triggers to turn on. I know the Kinect can get pretty warm just sitting there at the dashboard, and I'm a little paranoid that if I use it during the summer, the fan won't engage and I'll have one toasty-ass Kinect on my hands.
Normally I'd just say screw it and open it up, grab an adapter for the little fan's header, and then run it straight off USB, but I don't have Torx security bits to actually open the Kinect far enough to get to the fan.
TL;DR: How the hell does the fan in the 360's Kinect know when to turn on in hotass weather?
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/772422-xbox-360-kinect-fan-stuff/
probably a temp sensor like every other electronic device that requires a fan.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
Any idea where it is tho? Probs shoulda added that into the OP, but o well.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://www.ifixit.com/Teardown/Xbox+360+Kinect+Teardown/4066
fan is on the left side.
3 hours ago, vorticalbox said:
I meant a temp sensor, but in hind sight that's honestly more of a PITA than it's worse
Main rig on profile
VAULT - File Server
OptiPlex 7040M
it's probably built into the SOC .
