Hi guys and girls i really need help fault finding here.
Recently changed my Crossfire AMD R9 270x (2gb each) for Gtx 1050Ti 4GB.
ive made the change and My rig is now Shutting down when Playing games.
list of faults ive looked for -
. Ive deleted all software for previous graphic cards. (so not software)
. PSU is brand new out of box 2 months in use its a EVGA 750B (PSU)
. Taken RAM sticks out and tried individual ones which didnt help (RAM)
. recently bought a CPU Cooler (Cool master Hyper 103).... checked the heat sink/reapplied (CPU)
.Cable management i no longer use the VGA cables from PSU and seen a thread with someone saying it could be that....
. GPU - new from PC WORLD very much doubt its a malfunction dud, but ive been watching movies on this card without any crashes only when i play a graphically intense game it will turn off (not shut down..literally no power... need to take plug out of wall and wait a few seconds until any sort of boot up is possible)
MOTHERBOARD- Everything points too GPU and motherboard not being compatable ive researched online and seen people with my motherboard. (ASROCK FM2A88X Extreme4+) with the card.
Now heres the question is it as obvious as needing to change boards or is it something that isnt money consuming.
RIG setup-
CPU-AMD A10 Black edition 4ghz 100w
Ram- 8gb Corsair Venegence - 2x4Gb Corsair venegence (BLACK STICKS)
Psu - EVGA 750w Bronze
Motherboard - ASROCK FM2A88X Extreme 4+
Optical Drive - Blu Ray reader (nothing special)
CPU Cooler - Cool Master 103 Hyper (blue led)
Hard Drive - 2x 1Tb Western digital and Seagate
Case- CiT G force Gaming (green LEDx3)
ive DDU and taken out my old drivers, it says everything in my rig is compatable but im not sure anymore. Ive got a APU and im thinking its clashing
I know its alot of reading and i hope ive structured it for some of you's to tell me the obvious or not so obvious reason my Rig went from working to not in the space of a few short weeks. hope you can help
Thank you :D
https://linustechtips.com/topic/772300-i-need-help/
Have you installed the Nvidia drivers?
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
https://linustechtips.com/topic/772300-i-need-help/#findComment-9746024
1 minute ago, Jockkk said:
yes with the orignal disk and i checked for updates aswell.
Could your graphics card be messed up? You could try contacting the manufacturer and getting it fixed or replaced. I've got an EVGA SC 1050 Ti, and it works fine in my build of scavenged parts from various OEM computers.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/772300-i-need-help/#findComment-9746059
Dont use the drivers on your disc. There very outdated.
I would do a clean install from the latest driver online with no old drivers already installed from the CD
https://linustechtips.com/topic/772300-i-need-help/#findComment-9746079
I got the GPU from PC world brand new, PSU is defaintly ok, Card shouldnt be damaged but im gonna try get a replacement and go from there, Ive tried reinstalling the drivers ive done various ways. also risked updating my BIOS, CPU drivers and tried taking parts out and trying it. ZANDO BOB - have you ever used the same CPU/APU ?
https://linustechtips.com/topic/772300-i-need-help/#findComment-9746649
UPDATE*
taken the PC completely apart and started from scratch.
i re thermal paste the cooler and cpu
i reorganised it..... tested the GPU with a simple benchmark andddd whole rig Switched off compeletly.
so got curious tried benchmark with the lowest settings (while montoring CPU temp and load)
got to the very end and BANG whole rig switched off yet again.
Sending card off and replacing.
QUESTION: My AMD A10 cpu is FM2 - my motherboard states FM2 can only get PCI-e 2.0 - while the GPU needs PCI-e 3.0
Cards are backwards compabitble or have i found the issue ? im literally running out of options and ideas :(
https://linustechtips.com/topic/772300-i-need-help/#findComment-9747465
