Overwatch - High cpu usage and low gpu usage.
Solved by c0d0ps,
Update:
My new ram stick has come (another 1x8 GB same model) so now I have dual channel ram 16 GB (2x8 GB) instead of single channel ram (1x8 GB).
Overwatch still has high cpu (around 90% to 95%) usage but gpu usage is higher now and my lowest fps is around 152 to fps on lowest settings 75% render scale. Average fps is around 200 fps. I'll do more testing and then I'll answer any questions if someone had similar problems.
So far it seems like my performance is fixed. Dual channel 2133 MHz (motherboard doesn't allow higher) ram makes a noticeable difference at 144 Hz compared to 2133 MHz single channel ram. It is also worth checking your power saving settings though.
