4 minutes ago, yathis said:
try closing down all internet, use ccleaner and reboot
That seems a bit excessive, and would need international cooperation
https://linustechtips.com/topic/771725-issues-when-making-sig/#findComment-9739226
Can you post the output of http://www.whatsmybrowser.org/ (you can remove the IP if you want).
As I understand it, the issue you are having is that when you click into the editor, extra buttons appear on the toolbar (some of them duplicated). When you click away, those buttons disappear again. Is that right?
HTTP/2 203
https://linustechtips.com/topic/771725-issues-when-making-sig/#findComment-9740003
Yes that is all correct
Breaking things 1 day at a time
https://linustechtips.com/topic/771725-issues-when-making-sig/#findComment-9749155
