Yeah is its a streaming PC.. it doesn't need a 4Tb, or a PSU that big, or even that Keyboard. rather cut all those down, rather just do a 500gb SSD
and guys he doesn't need a 1070 as this is the Streaming PC he plays on his main rig and this just is the Capture PC, Otherwise it should be good, Its what I would use.
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
PCPartPicker part list: https://pcpartpicker.com/list/ZqNDNN
Price breakdown by merchant: https://pcpartpicker.com/list/ZqNDNN/by_merchant/
CPU: AMD Ryzen 5 1600 3.2GHz 6-Core Processor  ($218.98 @ NCIX US)
Motherboard: ASRock AB350 Pro4 ATX AM4 Motherboard  ($89.99 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($125.99 @ Newegg)
Storage: SK hynix SL308 250GB 2.5" Solid State Drive  ($80.49 @ SuperBiiz)
Storage: *Toshiba X300 4TB 3.5" 7200RPM Internal Hard Drive  ($137.88 @ Other World Computing)
Video Card: *Gigabyte Radeon RX 570 4GB Gaming 4G  Video Card  ($168.99 @ SuperBiiz)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($66.99 @ SuperBiiz)
Power Supply: VIVO 24K 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.99 @ Amazon)
Monitor: LG 27UD58-B 27.0" 3840x2160 60Hz Monitor  ($395.34 @ Amazon)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($28.75 @ Amazon)
Other: Elgato Game Capture HD60 Pro, stream and record in 1080p60, superior low latency technology, H.264 hardware encoding, PCIe  ($185.99 @ Newegg)
Total: $1574.38
Generated by PCPartPicker 2017-04-25 18:57 EDT-0400
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
4 minutes ago, Being Delirious said:
the 1050ti WILL NOT GAME AT 4K, crash and burn.
3 minutes ago, nerdslayer1 said:
1070 should if you can turn down some settings. https://pcpartpicker.com/list/LvDKgL
"streaming"
Full Specs
Helios EVO (Main):
Delta - Laptop
Just now, JDE said:
"streaming"
did not read properly sorry
Total: $1574.38
THANK YOU VERY MUCH I LOVE YOU AND ALL BUT WE KNOW.
lttstore.com
than why you going on about the 1050ti will crash and burn... Seems like someone doesn't know and all.
Redstone:
Obsidian:
PCPartPicker part list: https://pcpartpicker.com/list/gdMDNN
Price breakdown by merchant: https://pcpartpicker.com/list/gdMDNN/by_merchant/
CPU: AMD Ryzen 5 1600X 3.6GHz 6-Core Processor  ($248.99 @ SuperBiiz)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($99.99 @ Corsair)
Motherboard: ASRock Fatal1ty X370 Gaming K4 ATX AM4 Motherboard  ($138.99 @ SuperBiiz)
Memory: Patriot Viper Elite 16GB (2 x 8GB) DDR4-2666 Memory  ($97.99 @ Amazon)
Storage: ADATA Ultimate SU800 256GB 2.5" Solid State Drive  ($89.99 @ Newegg)
Video Card: Asus Radeon RX 580 8GB ROG STRIX Video Card  ($274.99 @ Amazon)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case  ($64.99 @ B&H)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($84.89 @ OutletPC)
Monitor: Asus VP228H 21.5" 1920x1080 60Hz Monitor  ($109.99 @ B&H)
Keyboard: Corsair STRAFE Wired Gaming Keyboard  ($79.99 @ Amazon)
Total: $1476.79
Generated by PCPartPicker 2017-04-25 19:00 EDT-0400
lttstore.com
Why you quote my second post?
Full Specs
Helios EVO (Main):
Delta - Laptop
Total: $1574.38
This is tops ! ! Well played sir, Can even dial back the 4Tb to a 2Tb and should be perfectly under budget.
Redstone:
Obsidian:
Or I could use a RX550.
Full Specs
Helios EVO (Main):
Delta - Laptop
PCPartPicker part list: https://pcpartpicker.com/list/p3sW8K
Price breakdown by merchant: https://pcpartpicker.com/list/p3sW8K/by_merchant/
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Video Card: Asus GeForce GTX 1050 Ti 4GB STRIX Video Card  ($159.99 @ Amazon)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.39 @ OutletPC)
Total: $1281.18
Generated by PCPartPicker 2017-04-25 19:02 EDT-0400
lttstore.com
12 minutes ago, Being Delirious said:
Oh no offense but this is a very unbalanced build.
1. dedicated streaming pc, not gaming pc
2. I should have mentioned that I plan to record the footage in raw as well and delete old footage on maybe a monthly basis. (my bad)
3. the 4k monitor, and keyboard are "nice to haves" to improve my current gaming setup, they will be replacing older stuff i'm currently using (my bad again)
3. the 4k monitor, and keyboard are "nice to haves" to improve my current gaming setup, they will be replacing older stuff i'm surrently using (my bad again)
PCPartPicker part list: https://pcpartpicker.com/list/msvYzM
Price breakdown by merchant: https://pcpartpicker.com/list/msvYzM/by_merchant/
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.99 @ Amazon)
Keyboard: Thermaltake POSEIDON ZX Wired Standard Keyboard  ($65.99 @ SuperBiiz)
Total: $1586.62
Generated by PCPartPicker 2017-04-25 19:05 EDT-0400
EDIT: That keyboard is mechanical.
Full Specs
Helios EVO (Main):
Delta - Laptop
Total: $1586.62
do I need an SSD on a pc JUST for streaming?
that HDD only bums up the price
that GPU ALSO only bumps up the price, it's CPU encoding I don't really need a big gpu
the case is a plus
the PSU looks like a plus
that keyboard is a step DOWN from what I'm using not UP
and the $1500 budget is a top CAP as in DO NOT EXCEED THIS AMOUNT
thank you.
the case is a plus
thank you.
BUTS ITS A MECHANICAL KEYBOARD!
Anyways here is one without a keyboard upgrade
PCPartPicker part list: https://pcpartpicker.com/list/mfk7qk
Price breakdown by merchant: https://pcpartpicker.com/list/mfk7qk/by_merchant/
Video Card: *Gigabyte Radeon RX 460 4GB WINDFORCE OC Video Card  ($114.99 @ Amazon)
Total: $1477.13
Generated by PCPartPicker 2017-04-25 19:20 EDT-0400
And here is one that does!
PCPartPicker part list: https://pcpartpicker.com/list/bqVHD8
Price breakdown by merchant: https://pcpartpicker.com/list/bqVHD8/by_merchant/
Case: Corsair SPEC-01 RED ATX Mid Tower Case  ($46.99 @ Amazon)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.98 @ NCIX US)
Keyboard: Cooler Master MasterKeys Pro L Wired Standard Keyboard  ($119.99 @ Amazon)
Total: $1496.12
Generated by PCPartPicker 2017-04-25 19:26 EDT-0400
Full Specs
Helios EVO (Main):
Delta - Laptop
Yeah running a Mech KB on a second computer is as useful as fitting slicks to a 4x4, its a large waste as you will be using it very little. I'd rather use the S340 but as budget is a part just grab any old case that'll fit the parts, nothing there is over large or requires anything funny,
also SSD is a must ! ! the encoding is handled by the HD60 but it still all interfaces through a OS.. SSD make that faster :)
I would just grab a cheapy Microsoft KB+ms or the SM Devastator linked earlier, thats a good combo for that Gam3r L337 look
Redstone:
Obsidian:
