There is no such thing as a nice pair of beats. But in theory there should be no difference between mobo io and front panel
qυoтe мe pleaѕe!
Me at the Apple store: "So how fast is this little macbook?"
Apple employee: "Cheetah Fast. Lightning Fast. It's Really, really, fast."
https://linustechtips.com/topic/771444-audio-quality-comparison/#findComment-9735783
Use the rear I/O whenever possible. The front panel is typically unshielded inside the computer, so there's a good chance to pick up noise.
Or you know, you could try all three and pick whichever sounds best.
https://linustechtips.com/topic/771444-audio-quality-comparison/#findComment-9735800
If you have an older motherboard or cheap case definitely go with morherboard i/o. If you have a new motherboard and a decent case the difference between motherboard i/o and front panel audio connectors shouldnt be noticable with such devices you like to connect to them. Dont use the g510 port.
https://linustechtips.com/topic/771444-audio-quality-comparison/#findComment-9735809
Just test and see if you can hear a difference.
Some motherboards offer better headphone amp with the rear I/O and some offer better amped with the front panel
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/771444-audio-quality-comparison/#findComment-9736279
