Setting up a surround system but my BluRay remote isn't working "Remote control 2"
Solved by GuruMeditationError,
Okay...I think I've found the answer:
- The remote control and this unit are using different codes. If “SET 1 or 2” or “Remote control 1 or 2" is displayed on the unit’s display when a button is pressed on the remote control, change the code on the remote control.
Press and hold [OK] and the indicated number button at the same time for more than 5 seconds.
http://eng-ca.faq.panasonic.com/app/answers/detail/a_id/23038/kw/23038?a_id=38992&~=troubleshooting---the-remote-control-does-not-work-properly.---blu-ray&session=3bQKg-gn
That seemed to be it; for future reference, I held the "OK" button and the "2" button for 8 to 10 seconds and now my remote control works with the unit.
