Receiver or No Receiver?
Solved by johnt,
11 minutes ago, madsolar8582 said:Well, the soundbar is a 5.1.2 system, so it is advertised as an Atmos system. But I think you're right about the pricing of the switcher. I found this one for ~$480 which is just shy of the two receivers I mentioned above.
Yup that's God's switch right there. Advertised is a harsh word to accept in this case. Atmos requires directional speakers and unless your room is a perfect box and your couch is in the right spot and you only sit in the center of everything and venus aligns with saturn and pluto catches on fire, then I wouldn't hang my hat on the Atmos stuff from a bar.
Go for Denon. They specialize in home theater equipment.
