Hi looking to get a evga 1050ti FTW for a pretty nice price. I'm aware they are 75w cards and are supplied through pcie power but the card has a power connecter. I'm worried I'll need xtra power and I cannot supply it as my psu doesn't have a pcie cable. I could adapt one but perfer not to as its an old dell 400w from the prehistoric ages. Hence why getting a low power card.
Main system:
i7 6700k @4.8ghz 1.45v
ROG Maximus Hero VIII
Gigabyte G1 980ti Sli @1500 ghz
Samsung 950 pro 512gb
16gb G.Skill Ripjawz V @3400mhz
Corsair H115i 280mm AIO
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Intel i3 6100 @4.6ghz 1.52v
Asrock B150M Pro4/Hyper
Intel 750 series 400gb
Radeon Rx 470 XFX
Thermaltake Water 3.0 360mm AIO
inWin 303 case
AMD Phenom II x4 940 @3.9ghz 1.65v
Gigabyte 780g mobo
Corsair H100 240mm AIO
Corsair Dominiator 8gb DDR2 @1066
Evga GTX 750ti FTW @1450mhz
Thermaltake Matrix case (modded)
"The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage"
https://linustechtips.com/topic/769797-1050-ti-doesnt-need-power/
7 minutes ago, nerdslayer1 said:
get a new psu before it explodes, using a old psu especially from a OEM build is not safe.
Total system draw with the 1050 is around 300w and I think the psu is 430w or 420w. It should be fine and the psu has been solid as a rock for me. I no I should but I don't NEED to so yea..
but will the card still run on only the pcie power?
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
Unless it;s a delta one. They're okay, I guess. Or seasonic. They're probably good.
M1 MacBook Air 256/8 | iPhone 13 pro
old oem PSU, its solid until it starts a fire.
1 minute ago, Damascus said:
Either take  @nerdslayer1s advice or get a 1050 ti/1050/rx 460 without that pcie cable
are you sure of this? I know some of the 750ti had power cables. It would still run without it
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
Why bother?  its a card that barely needs a fan, why get an over-engineered EVGA shroud? buy the cheapest one you can get :/
Want to custom loop?  Ask me more if you are curious
That's quite a bit of an exaggeration IMO
75W is still quite a bit of heat.
imagine saying that the core i7 7700 (Non K) didn't need a fan because of it's 65W TDP
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
Its Basicly the same price as the other cards and in getting it 130$ NZD cheaper than retail for a new product. The ssc edition is 290 and the FTW is 330(if they were available here) and I'm getting it for 206$. it makes no sense buying a worse card for more.
As as far as I'm aware the added pcie connector is for overvolting for higher ocs. I just can't find anywhere saying it will run without it or not...
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
If you need a dirty cheap good PSU the EVGA 430w Bronze would do the trick
Personal Desktop":
Luna, the temporary Desktop:
Personal experience, I have the cheapest 1050 ti (single fan Zotac) and it cools it like a champ.  There are also models that straight up don't have a fan, fully passively cooled
If it won't run without the connector I'll prolly just get somthing a lil more powerful like a 570 or 580 and buy a new psu aswell. Buying a new psu to use a 1050ti defeats the purpose of what I'm hoping to achieve :/
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
3 minutes ago, RS2007GOD said:
RX 560 maybe? when it is available to you, I think there might be some that won't need pci-e power connections and it is fairly decent card...
Personal Desktop":
If I find out I can't I will look for a good deal on somthing without a connector. having owned a 750ti FTW I know they are great binned chips and overclock amazingly. Moderate overvoltage on it and I was getting close to 1600mhz on that thing.
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
Arnt they worse than 1050ti?
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
By like 15% slower card but with the certain that it would run on your PSU.
Personal Desktop":
Right, there are 1050ti without the need for cables just the high end models have them for great overclocking. I just wanna figure out if it needs to use that or if it will function as a regular 1050ti without.. I also would love to overclock the snot outa it at some point lol
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
According to evga the FTW card has 4+1 power phases and 120w tdp where the SSC and lower cards are 3+1 power phases and 75w tdp. One site said it will run but have to downclock for it to be stable. :S
anyone with a FTW 1050 ti wanna test for me..?
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
