case fans(around 20$) and how many?
Go to solution Solved by Electronics Wizardy,
Id just stick with the stock fans, there really isn't a big imprement from adding any. Id stay away from the really cheap ones as they normally have cheap sleve bearing which can't be used upside down(on the top) and can be loud. Stick with the midrand 10-15 dollar ones
Guys. I would like to get some cheap(but not as sounding as a tank) case fans for my new PC build.
My specs are
Ryzen 5 1600 with the stock cooler
Gainward GTX 1070 Graphic card
Corsair 270r with included fans in this orientation(pic included)
Kinston Hyperx 16 gb ram
So how many fans do I need optimally? and any suggestions for the case fans?
And is it worth it to use 4 cheap case fans(sold in units of 4) like cooler master SI2 as case fans for reducing the temps?
https://linustechtips.com/topic/768752-case-fansaround-20-and-how-many/
Are you not satisfied with the stock fans?
Well, the parts are on their way. I am going to use the stock wraith spire cooler and I heard that it dissipates heat in all directions rather than a single direction. So was worried about excessive heat build up.
The case fans are there to move heat out of the case.
You can see how they perform before deciding on whether or not to buy new ones.
