4-Pin fan hub
Aker Brygge
Im wondering if I connect a 4-pin fan hub to my power supply ( since my MB only support 1 CPU_FAN and 2 CHA_fan(s) ) If fans connected to this hub would run at 100% all the time.
Welcome to the forums!
If you are using a power 4 pin PWM hub with a control cable connected to the CPU header and all the fans are 4 Pin PWM they will be able to change and vary speeds but any 3 pin fans on that hub will be running at full speed.
There are hubs that connect to the psu but are ran from a single fromthe mobo. Using the switftch myself for 7 fans.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
