$200 (CAD) phone
Go to solution Solved by Blackhole890,
7 minutes ago, kokakolia said:
I just bought myself the Zuk Z2 for $240!
Thanks guys! I think that it's a steal for the price. I also appreciate that it's a known brand (Lenovo) as well.
good! if you have any issue, dont be shy and ask me so i can try to help you :)
Hi,
I want to upgrade my BLU Advance 5.0 HD smartphone. Here are the specs:
  • Unlocked Dual Sim Smartphone, Android 60 Marshmallow
  • 50-Inch HD Display with IPS technology Made from Real Aluminum metal not plastic
  • 8MP Main Camera Plus 2MP Front Camera; 8GB Internal Memory 1GB RAM Micro SD up to 64 GB
  • MediaTek MT6580 13 GHz Quad-Core processor with Mali-400 GPU
  • GSM Quad Band 4G HSPA Plus (850/1700/1900): US Compatibility Nationwide on all GSM Networks including AT and T, T-Mobile, Cricket, MetroPCS, Straight Talk, Pure Talk USA and other
It was only $90 (cad) on amazon.ca. I abused the max out of it over the course of 1 year. Let me explain what I don't like about the phone:
- Sluggish performance and occasional freezing. It's a mild exaggeration, it runs fine with no more than 2 apps at a time. Picture-heavy websites will crash eventually though. It's still perfectly capable of running Chrome and YouTube smoothly. So it's not a brick! But rather a dying hero!
- Speakers distort at higher volumes. They're still plenty loud and perfectly serviceable for videos.
- Touch screen is not accurate, thankfully the auto-correct makes texting easy
- Camera is grainy, with poor auto-focus. Usually I don't care much about the camera, but I need one for taking snapshots of documents. It does a poor job at that and it makes me sad.
- It doesn't run Pokemon Go without losing GPS signal
- I'd like it to run Hearthstone as well. I need at least 2gb of RAM for that.
So I don't technically require an upgrade. My current phone is perfectly (barely) serviceable, since I almost exclusively text, surf the web and watch videos.
My problem is that there are too many smartphones out there. Here are my top pics:
ASUS Zenfone 3 Max
http://www.bestbuy.ca/en-ca/product/asus-asus-zenfone-3-max-16gb-smartphone-grey-unlocked-zc520tl/10516458.aspx?
It runs an unspecified "quad core" MediaTek chip, so I'm not too thrilled.
Sony Xperia XA
http://www.bestbuy.ca/en-ca/product/sony-sony-xperia-xa-16gb-black-unlocked-refurbished-f3113/10496025.aspx?
It runs a Mediatek Helio P10 which seems promising.
Motorolla Moto G Play 4th gen:
http://www.bestbuy.ca/en-ca/product/motorola-motorola-moto-g-play-4th-gen-16gb-smartphone-black-unlocked-refurbished-xt1607/10515530.aspx?
Snapdragon 410 seems dated, but I used to own a Moto G 3rd gen and it was an awesome phone.
Xiaomi Redmi 4X:
http://www.gearbest.com/cell-phones/pp_616201.html?wid=21
It seems like the best choice on paper.
Xiaomi Redmi 4a:
http://www.gearbest.com/cell-phones/pp_617027.html?wid=4
Only $130, but it looks like some features were cut from the 4x to reach that price. The case is plastic over metal. You get a Snapdragon 425 instead of a 435.
Asus Zenfone 3 Laser:
https://www.amazon.ca/ASUS-Zenfone3-Unlocked-Smartphone-Android/dp/B01LQV1YHO/ref=sr_1_1?s=electronics&ie=UTF8&qid=1492362835&sr=1-1&keywords=asus+zenfone+laser
Over budget @ $270. It runs a snapdragon 430. But it looks like the build quality, screen and camera are better. Personally, I don't see the point of getting anything sharper than a 720p screen. Sure, the text is sharper. But why would I read small text anyway?
Ulefone Power 4g:
http://www.gearbest.com/cell-phones/pp_288826.html?wid=11
Another choice. I don't know anything about the CPU MTK6753 . It has a nice screen though. And I love bamboo.
Edited by kokakolia
missing info
https://linustechtips.com/topic/767343-200-cad-phone/
Elephone S7? Huawei phones?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/767343-200-cad-phone/#findComment-9689570
You mean this?
http://www.gearbest.com/cell-phones/pp_489748.html?wid=11
Seems good. It's $50 over-budget. But it seems worth it if the screen and performance is better.
EDIT: How much better is the S7 over the Xiaomi Redmi 4x? It's an $80 gap.
Edited by kokakolia
missing info
https://linustechtips.com/topic/767343-200-cad-phone/#findComment-9689578
You mean this?
The S7 has a curved screen and Helio X20.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/767343-200-cad-phone/#findComment-9689621
Just now, kokakolia said:
The curved screen frightens me a little. I am brutal with my smartphones. I always use a tough case and glass screen protector.
Its literally the same design as the S7 Edge.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/767343-200-cad-phone/#findComment-9689631
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/767343-200-cad-phone/#findComment-9689641
letv x820 or zuk z2 plus, i have one so if you have any problems/questions you can ask me :D
You mean this?
https://www.kimovil.com/en/compare/elephone-s7-3gb-32gb,xiaomi-redmi-4x
its not officially "curved". The glass are curved but not the display itself so it looks like curved
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/767343-200-cad-phone/#findComment-9689644
I see, so it's like an S7 for the fraction of the price.
not at all, just bezeless with a good 2.5D curved glass, the display is not curved
https://linustechtips.com/topic/767343-200-cad-phone/#findComment-9689654
Yes, except for a less powerful processor and a lower resolution screen (1080p)
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/767343-200-cad-phone/#findComment-9689657
Well, its kinda a optical illusion type thing
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/767343-200-cad-phone/#findComment-9689661
Okay, here's an informative video talking about the cons of the Redmi 4x:
Basically, the camera app is stupid. The video recording quality is bad. The audio recording quality is bad. Everything else is average or good. I might just get that phone. It looks like I'll be perfectly content with it.
I am looking at the Zuk Z2 and it looks like an awesome phone for $260 CAD. Might be worth the extra $100.
http://www.gearbest.com/cell-phones/pp_612134.html?wid=11
As always with tech, you set yourself a budget and it's always broken.
So far I am considering:
- Xiaomi Redmi 4x
- Lenovo Zuk Z2
Any other suggestions?
https://linustechtips.com/topic/767343-200-cad-phone/#findComment-9689693
The Lenovo Zuk Z2 is sold for $240 here:
http://www.banggood.com/Lenovo-ZUK-Z2-5_0-inch-4GB-RAM-64GB-ROM-Snapdragon-820-2_15GHz-Quad-core-4G-Smartphone-p-1064299.html?rmmds=detail-left-hotproducts
I think I'll just get that one. It's a little more expensive than the Redmi 4x, but everything seems better.
@Aytex The Redmi Note 4 is the one I was looking at.
https://linustechtips.com/topic/767343-200-cad-phone/#findComment-9689764
https://linustechtips.com/topic/767343-200-cad-phone/#findComment-9689854
