First Build
Go to solution Solved by DocSwag,
I'd suggest a 1600 instead as well as an rx 480 8gb, otherwise looks good.
Hey guys!!
I'm planning to build my first computer and I need some advice.
I'll be using it mostly for gaming (I play almost everything so I can't specify... FarCry, Rainbow Six Siege, Crysis (I hope XD), GTA V, CS:GO, LOL) but also some 3D/CAD work in SolidWorks and some programing in MatLab (although no so often).
Specs:
CPU: Intel core i5-6600k
MoBo: MSI Z170A-G43 Plus
Memory: G.Skill Ripjaws V Series 16GB (2x8) - DDR4 2400
Storage: SSD: Samsung 850 EVO 250GB (and HDD: WD Black 1TB 7200RPM --> I'll add later)
GPU: MSI GeForce GTX 1060 Armor 6G OCV1
PSU: Corsair CX550M
Case: NZXT S340 Elite
CPU Cooler: Cooler Master Hyper 212X
Fan: Corsair Air Series AF120mm Quiet Edition
On my country this makes a total of around 1100€ without monitor nor peripherals.
So, what do you think? What would you change within my budget (~1000€)?
Also, I plan to add more 16GB of RAM later. Do you think it is too much of an overkill? And I'm thinking on adding a 2nd monitor when I have money, is SLI that important for a good performance on a 2 screen display? Should I bet on a SLI compatible motherboard right away?
(Sorry for any spell mistakes)
EDIT: My main goal is gaming
https://linustechtips.com/topic/766910-first-build/
if you're going to use cad or cpu bound applications, you should change to ryzen 1600, because more cores and threads will improve time rendering
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/766910-first-build/#findComment-9684616
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/766910-first-build/#findComment-9684617
No, get an i7-7700 (non K) and a B250 motherboard instead ;)
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/766910-first-build/#findComment-9684622
This is what I would recommend, but Ryzen doesn't seem to perform very well in GTA V :/
https://linustechtips.com/topic/766910-first-build/#findComment-9684635
My goal is gaming... isn't intel better for that?
https://linustechtips.com/topic/766910-first-build/#findComment-9684636
Depends on the Intel CPU...
https://linustechtips.com/topic/766910-first-build/#findComment-9684641
Not necessarily. Intel wins in averages but Ryzen wins in minimums, which arguably are more important.
http://www.gamersnexus.net/hwreviews/2875-amd-r5-1600x-1500x-review-fading-i5-argument/page-4
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/766910-first-build/#findComment-9684644
The 7700 is still better for gaming though...
https://linustechtips.com/topic/766910-first-build/#findComment-9684652
Compare to the i5s, which are getting really low .1% mins. It seems like a gta issue but it's there.
http://www.gamersnexus.net/guides/2878-gta-v-stuttering-mystery-on-i5-r5-cpus-part-2
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/766910-first-build/#findComment-9684659
Yeah, this is why I don't recommend i5s anymore :D
https://linustechtips.com/topic/766910-first-build/#findComment-9684662
But at the same time Ryzen is better for cad work, and has a better upgrade path. 7700 is about $100 more than a 1600 and mobos are maybe $50 cheaper. Ryzen is still cheaper.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/766910-first-build/#findComment-9684667
I didn't fully read the OP, derp xD
@Deux Alpha Get the Ryzen 5 1600, it is MUCH better for your needs!
https://linustechtips.com/topic/766910-first-build/#findComment-9684682
1 minute ago, Draknour said:
I would upgrade your power supply to 850 to 1000,
LOL, wut? xD
https://linustechtips.com/topic/766910-first-build/#findComment-9684694
Shouldn't need more than 16gb of ram, unless your talking about future upgrades, in which case, I would upgrade GPU 1st, since you can get more powerful gpus that will have an impact, instead of ram, which may/may not have an impact. Wierd everyone keeps talking about Cad, when OP said he is doing gaming
Current System Specs:
CPU: Intel I5-7660K; CPU Cooler: Coolermaster Hyper 212X; Thermal Paste: IC Diamond 7 Carat; Motherboard: MSI Z270 Gaming Pro Carbon;
RAM: Kingston HyperX Fury Black 16GB (2 x 8gb) DDR4 - 2400; SSD Storage: 1TB Samsung 850 EVO; Storage: 2TB Seagate Barracuda 7200rpm;
GPU: Gigabyte Geforce GTX 1070 8gb G1 Gaming; Case: NZXT Phantom 530 Black; PSU: EVGA Supernova G2 650W 80+ Gold, OS: Windows 10 Home
https://linustechtips.com/topic/766910-first-build/#findComment-9684696
Read da OP :D
https://linustechtips.com/topic/766910-first-build/#findComment-9684702
that vid card she is looking at is a power hog, double it up add it another ssd and a hdd and she will be close to, or over her psu limit.  from my experiance when you get close to or exceed your limit it usually does not just crash, instead you end up with a gremlin of errors, first ram, then hard drive, it seems random but I have seen it happen.
https://linustechtips.com/topic/766910-first-build/#findComment-9684706
Just now, PCGuy_5960 said:
Read da OP :D
Thats my point, since my main goal is gaming is it worth going with a Ryzen?
https://linustechtips.com/topic/766910-first-build/#findComment-9684712
WTF? The 1060 doesn't draw more than 120W under load...................................................................................................
https://linustechtips.com/topic/766910-first-build/#findComment-9684713
12 minutes ago, Draknour said:
that is alot of power draw as it stands, add in more ram, and another good vid card and your gonna start having issues, I would upgrade your power supply to 850 to 1000,
550 watt will be fine lmfao, where are you getting your information? His/her system is drawing 332w, at most he should do is a 650w.
Also, I'd maybe change your WD black to a WD blue and save some cash.
https://linustechtips.com/topic/766910-first-build/#findComment-9684719
Yeah, if you want to stick to Intel though, get an i7-7700. Either way, don't get an overclockable i5!
https://linustechtips.com/topic/766910-first-build/#findComment-9684721
hahaha yes, it doesn't go above 350W
Although I am aware that i'll have to change the power supply if I want to put one more GPU
https://linustechtips.com/topic/766910-first-build/#findComment-9684731
adding in more ram, sli... looks like another vid card too, now lets take consider overclocking and maybe watercooling, now you have an issue, and evga semi modular 850 is not that expensive, but it is better to have that capacaty to expand with now than to have to buy anotherone down the road.
https://linustechtips.com/topic/766910-first-build/#findComment-9684734
