var select = "SELECT SenderID,Subject FROM Mail where UserID='Admin1' ORDER BY ID DESC";
i want to display some data from the database in a datagridview  in descending order. i can select the data and show it but when i add the ORDER BY ID DESC to the query it doesnt work.i think my query is wrong.what could really be the issue.
7 minutes ago, madknight3 said:
Is "ID" a column in the "Mail" table?
Oh thank you for showing it. it should be UserID.changing it to UserID did show an out put in the datagridview but it was not in descending order.any ideas what is wrong?
3
It's hard to know exactly what's wrong without seeing your data. The best way to know for sure is for you to post some test data and the correct order you want the data to be displayed. I'll give a couple guesses below though.
It could be that what you really want is to ORDER BY SenderID and not UserID. Example.
Given this data
SenderID, Subject, UserID
1, "Subject 1", Scott
2, "Subject 2", Admin
3, "Subject 3", Betty
Using ORDER BY UserID will sort it like this
Since you aren't selecting UserID it could be that it just looks out of order.
2, "Subject 2"
3, "Subject 3"
1, "Subject 1"
Using ORDER BY SenderID will return this
Or it could be that because you're using a string and not a number for your UserID column, it's sorting lexicographically and it's not doing what you want. Example.
Say you have this data
UserId
Admin1
Admin2
Admin100
You might think "ORDER BY UserID" will result in the above order. However, it will actually result in this order.
Admin1
Admin100
Admin2
Because the database doesn't look at the numbers at the end of the UserID as an integer.
  • 2 weeks later...
