Will they be much quieter, while also moving more air? Absolutely.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
https://linustechtips.com/topic/765953-be-quiet-case-fans/#findComment-9673769
i agree with @Kobathor, they will be better in pretty much every way. this doesn't mean they will be absolutely silent when you put them to 100% though. thankfully that shouldn't ever be needed with casefans.
https://linustechtips.com/topic/765953-be-quiet-case-fans/#findComment-9673797
SW2's are much quieter. That being said, the stock FN V2's that come with the S340 aren't loud unless you run them at high rpm.
https://linustechtips.com/topic/765953-be-quiet-case-fans/#findComment-9677447
