Hi so I have the msi 760 gm p23 fx and I'm about to upgrade my CPU to the amd fx 8350 the site says I can use it the main thing is idk if I need to update the bios before installing it I don't think I do cause I bought my pc in 2016 and the last update for my board was 2015 so I assume I'm good ? Help!
https://linustechtips.com/topic/765797-bios-help/
updating the bios is always good, unless you screw it up
Desktop benching:
https://linustechtips.com/topic/765797-bios-help/#findComment-9672129
DO NOT put a FX-8350 in with THAT motherboard.
FOR THE SAKE OF YOUR SAFETY.
The MSi 760GM-P23 (FX) is based on the old 760G chipset -- it came out during the socket AM2+ / early AM3 days in 2008/2009.
This was way before 'Bulldozer' and 'Vishera' on AM3+. This chipset was never INTENDED to work with AM3+ CPUs.
MORE importantly, this motherboard uses a WEAK 3+1 VRM power phase design.
Not only that, there are no form of heatsink over those VRM's to provide any type of direct cooling.
According to the VRM database over at Overclock.net, this motherboard is KNOWN for problems.
There is no protection (e.g. overheat protection) in place for the VRM's.
It also uses a 2-transistor configuration compared to 3, 4, or more on other motherboards.
http://www.overclock.net/t/946407/amd-motherboards-vrm-info-database
If you check MSI's 760GM-P23 (FX) webpage, this motherboard DOES NOT support the FX-8350 -- or any 125W or high rated CPU's for a matter of fact.
This motherboard cannot support the higher power demands of these processors.
https://ca.msi.com/Motherboard/support/760GM-P23-FX.html#support-test
https://ca.msi.com/file/test_report/TR19_24433.pdf
You could consider something like the more "power efficient" FX-8320E or FX-8370E, but please keep an eye out, for the first little bit, for any odd behaviors or abnormalities with your CPU and/or motherboard.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/765797-bios-help/#findComment-9672654
