Good day,
I was running a GTX 560ti with an MSI z77 mobo, 12gb ddr3 ram and an Intel I5 3400 mhz ivy bridge CPU.
This setup ran games like the witcher III and PCars just fine.
Now i have switched to my GTX 560ti with an MSI A88 v2 mobo (fm2+), 12GB ram and an AMD A10 7850 3700 mhz Kaveri CPU
But now the games stutter alot and it's basically un-playable.
I have installed the latest drivers via Geforce Exp, but don't know what to do now..
https://linustechtips.com/topic/765113-gpu-does-not-perform-in-new-system/
8 minutes ago, Vreem said:
Good day,
Instead of upgrading you've downgraded by going with a worse CPU than you had before.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
Are you using a fresh install of your OS?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
19 minutes ago, Vreem said:
Good day,
Probably a CPU bottleneck
i like trains 🙂
16 minutes ago, Vreem said:
Allright, what are your recommendations on an fm2+ cpu?
The platform itself doesn't really have any CPUs that can match the i5's performance. The A10 7850K is almost as good as you can get. All I can really recommend on FM2+ is to overclock what you have if you can.
Sounds good. Have you looked at Ryzen?
I have, but it does not support the form factor used in the Node 202, i want to have as much power as i can pack into a tiny box.
I think i'll go with the set i specified, maybe a 1070 later on.
But i could always use opinions and tips.
