evo or pro
Go to solution Solved by ARikozuM,
Not really. Unless you're looking for longevity (warranty), you should stick with the EVO.
i was looking at a 1tb 850 evo but whats the benefit of the pro vs the evo.
ie is it the £90 worth it
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/764774-evo-or-pro/
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/764774-evo-or-pro/#findComment-9660660
The Pro model use MLC flash over the TLC of the Evo series, it mainly helps with wear if you do very heavy writes to the drive but for general users in most cases the EVO series will never be exceeded.
https://linustechtips.com/topic/764774-evo-or-pro/#findComment-9660662
thanks
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/764774-evo-or-pro/#findComment-9660668
5 minutes ago, Abyssal Radon said:
I have a 500GB 850 EVO and a 500GB 960 EVO (M.2), personally the difference between EVO and Pro IMO don't warrant the 90 euro difference for a minimal performance bump.
For m.2 it's totally different, it's
960PRO > 950PRO > 960EVO
950pro can be found cheap and is just behind the 960 so yeet
idk
https://linustechtips.com/topic/764774-evo-or-pro/#findComment-9660699
Nah, you're not pro ;)
https://linustechtips.com/topic/764774-evo-or-pro/#findComment-9660718
