how to cool a 6700k using a "Peltier device"
Solved by TonyKramer,
1 minute ago, SKinChangerGD said:oh that's why The Phononic HEX 2.0 TEC CPU Cooler has 6-pins...
Yeah, the 6 pin is just for 12V. Same connector you see on higher end GPUs. However, considering that the dissipation power on the Phononic cooler doesn't look to be the best (Its a air cooler), you might want to try to make your own solution with an AIO or custom water cooling setup.
