HTPC to 5.1 speakers help
14 hours ago, dalekphalm said:
I don't see how ARC would work in this scenario.
The Speaker System 1 HDMI output - for the Blu-Ray player. It has no HDMI input. Nor would the TV be on that particular HDMI input if he were using the HTPC. Unless ARC works even when a different input is selected?
I think using TOSLINK is the best choice - whether he does this via from the TV Output into the Speaker System, or if his PC happens to have TOSLINK out, he could directly do it that way.
Either way, @Vanguardas if your friend wants to keep that system, he should use TOSLINK. Otherwise, he should return it and get a Speaker System that has HDMI Passthrough instead (Generally more expensive though, and he might have difficulty finding one that also has a built-in blu-ray player).
The receiver/blu-ray player supports ARC just like a normal standalone home theater receiver would, I've had a few of these Samsung 5.1 systems and they've all supported it. I have the J5500W system connected to the HDMI-1 ARC input on a 55" Samsung TV, then I have a HTPC, satellite box, and a Wii U connected to to other HDMI inputs on the TV and it works perfectly.
