Got my hands on a 1080ti & 7700k Need help for new build
2 hours ago, Alkali A said:Ram-
8-16 GB is good and likely as much as you'll need, you can get 32 GB is you're willing to dish out a bit extra just for workload related items, and you could get 64 GB if you REALLY want to make you you have enough.
Speed wise it'll make more different the amount you have than what speed it is, as the slight improvements you get from faster speeds are so small that it can't even really be noticed.
That video has been debunked several, several times and unfortunately it still spreads the misinformation of "faster RAM doesn't do anything". Linus implemented such an awful testing methodology where he uses a mediocre GTX 660Ti with massively GPU-bound settings and doesn't even the minimum framerate, which is arguably the biggest improvement from faster memory.
The bottom line is that faster memory will give you higher minimum framerates and in CPU-bound scenarios (or where the CPU is the bottleneck), give you higher average frames per second.
One only has to look at the more recent Ryzen benchmarks or Digital Foundry videos to see that faster memory indeed makes a significant difference. People who say otherwise are just misinformed or don't know anything.
