This is going to be the first build I've done and am looking for some feedback to make sure everything is compatible. I was aiming to get a nice gaming rig that could run games like Arma 3 or Planetside 2 with a far render distance while still getting decent graphics. I'm planning on ordering either the 1400 or 1500x depending on performance.
Any suggestions would be appreciated
https://pcpartpicker.com/list/cMXT3F
I'm planning on getting another 8gb of ram at a later date.
https://linustechtips.com/topic/762573-my-first-build/
Nice choice on choosing the tesseract case!
I have a white one with a side window!
I honestly have no idea whats compatible and whats not, I'm still making my first build
https://linustechtips.com/topic/762573-my-first-build/#findComment-9636079
the z170 motherboard isnt compatible with the 7th gen cpus unless it has an updated bios so you are better off getting a z270 motherboard. also that ram is a bit overkill.
https://linustechtips.com/topic/762573-my-first-build/#findComment-9636092
3 minutes ago, Brooksie359 said:
and added a internal hardrive rather than an external one.
The HDD he had selected was a 2 tb enterprise edition internal HDD. Dunno where you've been looking, but the HDD you selected SEEMS to be worse. (considering warranty) Not enterprise edition, and only half the size.
https://linustechtips.com/topic/762573-my-first-build/#findComment-9636098
Don't get RAZER bruh.  The keyboards use knock off keys and the mice break down very quickly
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/762573-my-first-build/#findComment-9636101
What are you rambling about? Wrong topic? Topic starter is looking for Ryzen, and selected the following motherboard: Gigabyte GA-AB350-Gaming ATX AM4 Motherboard
https://linustechtips.com/topic/762573-my-first-build/#findComment-9636107
PCPartPicker part list: https://pcpartpicker.com/list/YrLhxY
Price breakdown by merchant: https://pcpartpicker.com/list/YrLhxY/by_merchant/
Motherboard: ASRock AB350 Pro4 ATX AM4 Motherboard  ($89.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory  ($69.99 @ Amazon)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($48.99 @ Amazon)
Video Card: MSI Radeon RX 480 4GB GAMING X Video Card  ($209.99 @ Amazon)
Case: Deepcool TESSERACT SW ATX Mid Tower Case  ($38.99 @ SuperBiiz)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($53.97 @ Amazon)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($92.99 @ Amazon)
Monitor: Acer XF240H 24.0" 1920x1080 144Hz Monitor  ($199.97 @ Amazon)
Other: Hitachi Ultrastar A7K3000 2TB HUA723020ALA641 (0F12470) 2TB 64MB Cache 7200RPM SATA III (6.0Gb/s) Enterprise 3.5-Inch Hard Drive  ($49.95 @ Amazon)
Other: R5 1500x ($189.00)
Total: $1043.83
Generated by PCPartPicker 2017-04-05 21:03 EDT-0400
This will play all of your games on the monitor very well, btw there is no need for a cpu cooler seeing as you can set the wraith spire to curve up to 100% if you want to oc.
8086k Winner BABY!!
Main rig
CPU: R7 5800x3d (-25 all core CO 102 bclk)
Board: Gigabyte B550 AD UC
Cooler: Corsair H150i AIO
Ram: 32gb HP V10 RGB 3200 C14 (3733 C14) tuned subs
GPU: EVGA XC3 RTX 3080 (+120 core +950 mem 90% PL)
Case: Thermaltake H570 TG Snow Edition
PSU: Fractal ION Plus 760w Platinum
SSD: 1tb Teamgroup MP34  2tb Mushkin Pilot-E
Monitors: 32" Samsung Odyssey G7 (1440p 240hz), Some FHD Acer 24" VA
GFs System
CPU: E5 1660v3 (4.3ghz 1.2v)
Mobo: Gigabyte x99 UD3P
Cooler: Corsair H100i AIO
Ram: 32gb Crucial Ballistix 3600 C16 (3000 C14)
GPU: EVGA RTX 2060 Super
Case: Phanteks P400A Mesh
PSU: Seasonic Focus Plus Gold 650w
SSD: Kingston NV1 2tb
Monitors: 27" Viotek GFT27DB (1440p 144hz), Some 24" BENQ 1080p IPS
https://linustechtips.com/topic/762573-my-first-build/#findComment-9636108
lol just saw it at the end and assumed it was a different section. my mistake.
https://linustechtips.com/topic/762573-my-first-build/#findComment-9636109
Ye that RAM is total overkill will probably downgrade a lil
and THANKS for letting me know my motherboard eats ass, ive been wanting to know if its compatible thanks for reals! :D
https://linustechtips.com/topic/762573-my-first-build/#findComment-9636113
I was going for a nice blue exterior and red interior
https://linustechtips.com/topic/762573-my-first-build/#findComment-9636127
5 minutes ago, Dutch-stoner said:
1307505786407_The_Off_topic_topic_post_3
Maybe not hyjack a topic? Maybe comment that stuff in that person his own topics? And considering he hasn't got an own topic, send him a PM? Or maybe suggest he should start his own topic?
it was one quick comment. didn't think i would get flamed over it lol. whatever the case is lets agree to stay on topic and not argue over how i derailed the thread.
https://linustechtips.com/topic/762573-my-first-build/#findComment-9636161
Made some changes, changed the PSU from 430W to 500W, the SSD from 120GB to 240GB, the GTX 10603GB to RX 480 4GB(I recommend 8GB) and finally get the windows 10 from kinguin, you can get a windows 10 pro key for $32. It's overall $30 cheaper so you can use the extra on going up to either 8GB 480 or Ryzen 5 1600 which would give you 6 core/12 threads as opposed to 4 core/8 threads.
https://pcpartpicker.com/list/KkmnFd
or
https://pcpartpicker.com/list/W2f6jc
https://linustechtips.com/topic/762573-my-first-build/#findComment-9636168
or
Geez, saved me $50 on the os. The 8gb gpu would only be needed for better texture quality, right?
https://linustechtips.com/topic/762573-my-first-build/#findComment-9636329
And if you plan to keep your PC for a few years, some new triple A games are already pushing 4GB video cards to it's limits so going 8GB is good for the long run.
https://linustechtips.com/topic/762573-my-first-build/#findComment-9636347
It's always about futureproofing lol
This will be my final version then unless the 1600 isnt worth the $30 extra
https://pcpartpicker.com/list/MsQT3F
Thanks for the help
https://linustechtips.com/topic/762573-my-first-build/#findComment-9636375
Thanks for the help
Actually, if your budget allows, go with this motherboard instead,
https://pcpartpicker.com/product/Y4kwrH/msi-b350-tomahawk-atx-am4-motherboard-b350-tomahawk
https://linustechtips.com/topic/762573-my-first-build/#findComment-9636459
I have been looking at the Tomahawk since it is the the mobo amd is sending out with the ryzen 5 review kits, but are there any obvious advantages that it has over the gigabyte? I noticed that the gigabyte has more usb 3.0 and 2 more sata ports while still being cheaper
https://linustechtips.com/topic/762573-my-first-build/#findComment-9636553
The Tomahawk has better reviews, MSI has better quality control imo compared to gigabyte and I think the MSI bios is better. The MSI also has a Type C port, where as the Gigabyte only has Type A.
https://linustechtips.com/topic/762573-my-first-build/#findComment-9636581
