Max Compatible Memory Speed for i7 7700 (Non-K)
Solved by MasamotoTakeshi,
Hey,
Your build looks pretty good and in regards to RAM the maximum supported speed should be the max speed supported by the motherboard. I have 16GB of 3200MHz in my system with no problems with the 6700K. Even though I have a 'K' CPU it shouldn't make a real difference as the 'K' just means it can overclock not difference in much else really (Aside from boost speed). The corsair vengeance kits are brilliant and you should have no problems with those. Please let me know if this helped.
