Hey everybody, today I had the idea to make a complete wooden case for all my PC hardware. I'm basically Going to use some scrap wood I have, and some new stuff I get for this build.
Materials:
    -Spare Wood
​    -Acrylic Plastic/Glass
    -Stain
   -Blue LED Inside lights (Or maybe white or yellow)
Components{Note: These will take a while do to the fact I need to make the case and cut some corners for the doe}
-Gigabyte FM2+/FM2 A88X (Bolton D4) Wi-Fi/BT4.0 SATA 6Gb/s USB 3.0 HDMI Mini ITX AMD Motherboard
-Corsair XMS3 8GB (1x8GB) DDR3 1333 MHz (PC3 10666) Desktop Memory
-Noctua Low-profile Quiet CPU Cooler for AMD Based Retail Cooling NH-L9A
-AMD A8-6600K Richland 4.3GHz Socket FM2 100W Quad-Core Desktop Processor
-WD Blue 1 TB Desktop Hard Drive: 3.5 Inch, 7200 RPM, SATA 6 Gb/s, 64 MB Cache
-Corsair Builder Series CX 600 Watt ATX/EPS  80 PLUS (Note: This is diffidently gonna change but I jsut have this at the moment.)
I will be working on the case off and on for the next few weeks, Ill post as many updates as possible. I could even make a few more to sale if you guys like the look.
Model:
Too be continued...
https://linustechtips.com/topic/75550-complete-wood-case/
Well, why not use something nice, like cherry or walnut wood?
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/75550-complete-wood-case/#findComment-1035331
I dont see a gpu there.. O_o
AMD FX-8350 @4GHz / Gigabyte 990FXA-UD3 / G.Skill RipJaw X 8GB 1866Mhz / Samsung 840 120GB SSD / Sapphire R9 270X Toxic / Corsair CX500 / Fractal Design Define R4 / Corsair K70 Cherry MX Blue / Xiaomi  Piston 2.0 / Steelseries Sensei / LG G3 32GB
https://linustechtips.com/topic/75550-complete-wood-case/#findComment-1035334
Do you know how you will mount the motherboard, hard drives, and power supply. Because when i built my wooden case that was the hardest part.
I5 3570k, Direct CUII 660ti, intel 330 180gb ssd, Asus maximus V formula.
"Woody" fully wooden computer case http://linustechtips.com/main/topic/26658-fully-wooden-computer-case-woody/
"Resurrection" a custom desk with and open design http://linustechtips.com/main/topic/74736-custom-desk-with-and-open-design-resurrection/
https://linustechtips.com/topic/75550-complete-wood-case/#findComment-1035358
Ya i was still working on the list, sorry I put a 650 ti on there. Sorry about that!
No need to be :) will look forward to the progress pics!
https://linustechtips.com/topic/75550-complete-wood-case/#findComment-1035370
I'm thinking I will make some wood frames for the drives and power supply I dont have a plan for the mother board yet, BTW your looks amazing.
https://linustechtips.com/topic/75550-complete-wood-case/#findComment-1035372
oh thanks if you saw how i mounted the hard drive i think it works really good just make sure it is sucure to the wood because hard drives can get heavy.
another thing is make sure every thing is STRAIGHT because if one thing is off then is will cause other problems which happened to me the top ended up to not fit perfectly.
Also did you see the build log or just my profile pic.
https://linustechtips.com/topic/75550-complete-wood-case/#findComment-1035432
I was actually planning on using it and having some nice white LEDs cause I have a white build plan for this. I think it contrast nice
Great, can't wait to see what turns out!
https://linustechtips.com/topic/75550-complete-wood-case/#findComment-1035455
just went to your profile and read through it, nice use of the clamps im going to have to use that :)
https://linustechtips.com/topic/75550-complete-wood-case/#findComment-1035473
Hey guys just wanted to give an update about my idea and give you an idea of my vision.
Design: Will elaborate more.
You might wonder why I don't have any side panels. That is because both the sides are gonna be acrylic. I'm gonna hang the mobo, graphics card, and heat sync. Tell me what you think of thats.
​Dimension:
3 ft by 3 ft
Questions
Do you think I should clear or crystal acrylic for the side panels, also I think Im gonna put custome cable covers to complete the color theme.
What do you think?
Any suggestions?
https://linustechtips.com/topic/75550-complete-wood-case/#findComment-1045947
Sounds delicious. Tell me when its done and upload pics lots of pics :D And maybe I'll buy it if its that smexy looking.
Lol alright I will cant work today though really hurt my finger  :blink:  Gonna get paid soon though so that will be awesome!! Plus I have an entire tool list I need
https://linustechtips.com/topic/75550-complete-wood-case/#findComment-1046156
Sounds sexy. Although I'd make the side with the back of the motherboard wood, and make a kinda wide space behind it so you can tuck some cables behind the mobo. Kinda like most modern cases.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/75550-complete-wood-case/#findComment-1046157
I gotcha
-Screwdriver
-Saw
-Sander
-Drill
-Screws
-Wood stain
https://linustechtips.com/topic/75550-complete-wood-case/#findComment-1046166
That's an interesting id ea I could just put a strip in the middle. Great suggestion!
https://linustechtips.com/topic/75550-complete-wood-case/#findComment-1046286
