Dark Rock 3 air cooler memory clearance
Solved by dfsdfgfkjsefoiqzemnd,
52 minutes ago, Brooksie359 said:im not sure if the same goes for the non pro version of the dark rock 3 but the pro version has issues with non low-profile ram
The non-pro is very likely to overhang the first DIMM slot indeed. Depending on the motherboard, the first PCI-e slot may also be an issue.
That being said, you can always move the fan up a bit to create room. But that's not a pretty sight.
@ OP : To give you an idea of RAM clearance on a 40mm high cooler, here's a Pro hanging over some Kingston HyperX Savage on an MSI X99A Gaming7 board :
That's fairly low-profile RAM. You're not going to get away with high-profile RAM, so stick with low-profile or get a cooler that has plenty of clearance.
